Lighting HID/Xenon kits, Retrofits and Associated Topics
92-95 civic coupe
Old May 13, 2008 | 10:11 AM
93dagsr's Avatar
Default 92-95 civic coupe
i can't seem to find an exact answer to this question:
what exact projector do i need to retrofit into my car?
can i use the
http://www.hidplanet.com/halogen.html
Bosch Mini H3 Projectors:
Another exclusive from HiDPlanet.com! 1.5" Bosch Mini Halogen Projectors (H3) are the perfect solution for driving lights to compliment your H.I.D. or for standalone use. These units are perfect for any project and their compact size will fit just about anywhere!
Bosch Mini Projectors provide a super sharp flat cutoff for foul weather conditions. Each pair comes with H3 bulbs.
Bosch Mini H3 Projector Dimensions:
Max Outer Diameter = 2 3/4"
Lens Diameter = 1 1/2"
Max depth = 3 3/4"
$45 a pair or ???
i don't really have $200 to spare on some projectors so will these work? can i still follow the same walkthrough you guys made up? lmk. thanks for your patience!
Old May 13, 2008 | 11:22 AM
denshu's Avatar
Default Re: 92-95 civic coupe (93dagsr)
Those are fog lights.
which gives width and no distance.
you won't be able to see anything ahead of you with this foglight projectors.
All it will do is light up the foreground.
If you don't have an extra 200 for projectors then don't do it at all.
You gotta pay to play
Old May 13, 2008 | 12:00 PM
93dagsr's Avatar
Default Re: 92-95 civic coupe (denshu)
o i see. ok then what projector do you guys recommend??
BMW M3 (E46) Bi-Xenon projectors
are these easy to put into my stock housing? i saw them and they're not too expensive.
this car has them and looks hella good! (magazine has a better view of them)
Old May 13, 2008 | 03:53 PM
12kv's Avatar
Get the TSX or FX35.
Old May 14, 2008 | 04:37 AM
pgpunkguy's Avatar
Default Re: (12kv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 12kv &raquo;</TD></TR><TR><TD CLASS="quote">Get the TSX or FX35. </TD></TR></TABLE>
x2, but if you go tsx (or any other single xenon) make sure you still have something for high-beams.
Old May 14, 2008 | 11:20 AM
93dagsr's Avatar
Default Re: (pgpunkguy)
single xenon means i can only have one beam? hi or lo?
bi-xenon means i can have both on one bulb? hi and lo?
Old May 14, 2008 | 12:58 PM
pgpunkguy's Avatar
Default Re: (93dagsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93dagsr &raquo;</TD></TR><TR><TD CLASS="quote">single xenon means i can only have one beam? hi or lo?
single xenon is low-only, but you can take it apart and remove (or mod) the shield to use it for high beams
bi-xenon has a solenoid that moves the shield to give you high and low in one projector.
Mr. H_Twizzle
10
Oct 13, 2010 07:32 AM
Zaraki
Lighting
Jun 8, 2008 11:29 AM
GTEC913
Feb 19, 2006 10:36 PM
ridiculous
Dec 11, 2002 07:16 AM
B_1_8_hatch
Nov 2, 2002 06:06 AM
