what is this called?
Old Nov 25, 2011 | 02:52 PM
VisionPaintball's Avatar
Default what is this called?
hey guys,
what is the adjustable rod on the bottom of the picture called? anyone know what size approximately too?
I would like to use a similar one to brace my turbo to the block somehow.
I see the rod ends here;
Left Hand Male Mild Steel Rod Ends at The Chassis Shop
any help would be appreciated.
Old Nov 25, 2011 | 03:12 PM
SovXietday's Avatar
Default Re: what is this called?
That is not really going to be a good option in helping to support the turbo, you need something more rigid.
Old Nov 25, 2011 | 03:41 PM
TinyT's Avatar
Care to elaborate on why that wouidnt be rigid? A proper bracket off the engine to a tab on the turbo with a turn buckle like that or a tube with weld slugs and rod ends will be more than enough.
doesn't show it too well but u get the idea...
racelab 240sx
Old Nov 25, 2011 | 04:36 PM
k24em2's Avatar
Actually used correctly it's quite good. It supports the weight of the turbo but still allows it to move when things get hot and start expanding.
Old Nov 25, 2011 | 04:49 PM
siblues's Avatar
swaged radius rod then you can purchase the ends that you need.Here is a link with some prices
http://www.kaedings.com/index.php?ma...l7fvg8tffiui87
Old Nov 25, 2011 | 05:25 PM
Thanks!!!
Google turned up some good stuff.
http://www.bufkinengineering.com/turbo_bracket.htm
http://www.pacificcustoms.com/mm5/me...Category_Code=
http://www.034motorsport.com/turboch...ace-p-704.html
Rod Short
Jun 3, 2007 09:08 AM
cor4ey
Sep 28, 2006 03:48 AM
turbodan4
Sep 11, 2004 10:43 AM
CIVILGSR
Jan 21, 2004 06:55 AM
Hayasa15
Mar 7, 2002 05:44 AM
