Just purchased a machine, issues.
Old Oct 12, 2011 | 08:45 PM
titwack's Avatar
Default Just purchased a machine, issues.
Hi all, I had just graduated from HIWT and i bought a TIG machine to make some manifolds and other automotive related stuff. I am not new to tig welding which makes this dilemma even more annoying. I bought a Diversion 180, comes with a Weldcraft LS17 torch air cooled, 3/32 2% ceriated. 3/32 collet and collet body, and a 7 cup. I am welding thin stainless (under 2mm) with about 15CFH of gas. For some reason every single weld comes out to be gray and too hot. Only welding about 30 amps. And my tungsten is also turning a black/blue. I know for a fact that it has to be a gas delivery issue and turning the gas up isnt a fix, or a fix i will settle for. I am going to go get a bigger cup but that shouldnt be the only fix. Any input? thanks!
Old Oct 13, 2011 | 06:02 AM
that-guy's Avatar
Default Re: Just purchased a machine, issues.
no pro at TIG, but changing just the cup will make a world of dfference. throw on a #10 and see how it goes. are you sharpening your Tungsten?
Old Oct 13, 2011 | 06:08 AM
FabChild's Avatar
Check to make sure the post flow on the machince is working, We had a Sync that just did that. Put a smaller tungsten to, 3/32 is WAY to big to be welding at 30 amps.
Old Oct 13, 2011 | 06:27 AM
titwack's Avatar
I am going to buy a gas lens and hopefully works out
the post flow is working for sure, about 10 seconds of postflow.
Old Oct 13, 2011 | 01:13 PM
titwack's Avatar
UPDATE:
just put on a #12 gas lens, coverage and color is a little better, using about 20CFH. still isnt shielding properly. All lines are tight and used teflon tape. Im stumped
Old Oct 13, 2011 | 02:39 PM
intense4thgen's Avatar
maybe the teflon is blocking the hole in the fitting also you do not need it for a 37* fitting to seal as most welder fittings are JIC fittings.
Old Oct 13, 2011 | 04:26 PM
titwack's Avatar
I'll give it a try, thanks
Old Oct 13, 2011 | 06:09 PM
titwack's Avatar
UPDATE:
Removed Teflon tape, still no difference in gas coverage
Old Oct 14, 2011 | 06:15 AM
CVC9216's Avatar
moving too slow? post some pics?
can you feel gas coming out? what's your post flow? Using pure Argon?
If nothing else works exchange your cylinder, might be bad gas or mix
Old Oct 14, 2011 | 06:59 AM
HellaFab's Avatar
turn your regulator up to an unreasonably high amount and try again.
are you using the ball type or the guage type regulator?
Old Oct 14, 2011 | 08:31 AM
titwack's Avatar
update:
It was a bad tank of argon. swapped out tanks at my supplier and runs perfect. pictures soon to come. thanks everybody
Old Oct 14, 2011 | 08:33 AM
bcumbie's Avatar
Originally Posted by titwack
update:
5thgen
Welding / Fabrication
Sep 30, 2011 09:12 AM
robbbby
Nov 11, 2007 06:39 PM
codenamezero
11
Feb 13, 2007 08:48 PM
1 2 NV
51
Jan 6, 2007 08:08 PM
shawnhayes
14
Jul 16, 2002 03:38 PM
