Pics of your tig torch setup :)
I ordered my new #9 torch with a large stubby gas lens and #12 cup, but the cup looks unlike most I have seen.
If anyone here uses the same setup I just listed, could you be kind enough to post a picture of your torch please
Re: Pics of your tig torch setup :)
Here's is my setup, pretty much the same you'll have
SR9 torch with weldcraft large gas lens + #12 cup
When I first got that cup I was shocked :D It was huge... but now it seems normal, and everything smaller - tiny
Good luck!
Good luck!
CK large diameter gas lense (1 1/8" iirc) on a WP #17 torch. air cooled.
I need to get some more lenses.... i cracked mine.
Those clear pyrex cups (gas savers) I have one, and used it a hand full of times. To get gas coverage comparable to a standard #12 cup I have the raise the regulator to around 40-55cfm. More like gas waster imo.
CRMB, i have not used a pencil torch before and have a question.... how does one HOLD the pencil torch? like a normal pencil or parallel to your forearm?
It would seem (without having used one) that the weight of the hose would be problematic when holding like a pencil without some overhead rigging to hold the weight of the hose.
I have one that came with my welder, but i have never bothered trying to hook it up.
Hey Wade,
Here is mine, its a wp20, but its pretty much a watercooled version of a wp9. Uses the same front end parts.
It has a 25ft braided hose, zip up cover and #12 gas lens. I dig it, just need one more part and I'm watercooled.
Thanks for introducing me to the smaller wp9/20 and the braided rubber hoses. I like them alot better than the wp17 setup I am used to.
DK
DK
OG Fabricator
You hold it like a pencil. I dont remember the cables being much of a concern but it has been more then a few years since I picked up a tig torch.
You'll need forearms like popeye to hold the weight of the cable I would have thought.
Took me some practice to get used to the large cup, now just every now an then I need to ditch the #12 to get into tight spots. A smaller torch has helped alot.
Nice setups!
It took me a little while to get used to the #12 also. At first it feels like you're welding with a shot glass at the end of your torch. It also takes little time to get a feel for the right gas flow rates. (True of any cup change).
I use a WP-17 with the regular gas lens and a #8 for anything that doesn't need to be super clean (AL, or SS that I will clean after welding). For SS pipe and tubing that needs to come out clean, I use the large gas lens with a #12 cup.
For gas flow, I use ~12 cfh for the small gas lens, or like ~20 when using more stick out, but it depends on the joint I'm welding, and where it's located etc ...
For the large gas lens, I usually always set it at ~20-22 cfh.
My torch has taken a beating and a half, I tend to break things when I get angry. Last time I whipped it against a chair and it hit the top of the chair back and bend into a U shape. I unbent it and it still works fine. But just recently I threw it down and the back-cap pulled out from the back and took the threads in the body out with it. So I need to get a replacement soon. Not sure if I want to get something different or not ...
