Wastegate flange options?
Old 10-09-2011, 01:44 AM
RadekSkylark's Avatar
Default Wastegate flange options?
Hallo guys.
I've gathered few brand wastegate options and wanted to ask questions about them - this topic is regarding to flanges, are they the same for all wastegate brands.
Ok, here's the list:
-Vibrant 50mm V-band
-Turbosmart 50mm V-band
-Synapse 50mm V-band
-Turbosmart 60mm V-band
-Tial 60mm V-band
-Tial MV-S (38mm V-band?)
-Tial MV-R (44mm V-band?)
-Old model Tial V44 - 44mm V-band
-Tial 38mm 2 bolt
-Turbosmart 38mm 2 bolt
The question is - are both Tial & Turbosmart 38mm 2 bolt flanges the same?
Are all the 50mm V-band flanges the same? And also are all the other size flanges the same?
I'm asking this to know, if I need to know exact brand of wastegate which will be used by customer... or do I only need to know that he want 38mm 2bolt or 44mm V-band and so on
Hope you get what I mean
Thanks alot
Old 10-09-2011, 05:02 AM
OG Fabricator
weiRtech's Avatar
Default Re: Wastegate flange options?
i've never seen a 2 bolt flange that was different. the 35/38mm pattern is standard across wg brands.
now the v-band is a different beast.
all the tial wg's have a different size flange between the wg inlet & outlet. make sure you order the correct one. i'm not sure if the new mvs wg's have different size or profile from the regular wg's. i've used both- but never put them side by to compare. i'd be surprised if they were different.
the synapse vband is different from the tial- but the inlet & outlet flange are both identical so you don't need to worry about mixing them up.
i haven't used too many turbosmart wg's but i believe their vbands match the tial ones.
vibrant doesn't sell their own wastegates- just the flanges. the description/name of the flange will dictate which which wg it goes with.
most wastegates come with flanges for fabrication. you really only need to be concerned if a customer provides you with a used wg with no flanges.
Old 10-09-2011, 06:43 AM
So, all those 35/38mm 2 bolt flanges are the same and I don't need to know exact brand... if customer requires 38mm 2 bolt, I cannot miss with flange options Correct?
But for all V-band options it is the best thing to know which exact wg will be used, to weld on the right flange, correct?
Old 10-09-2011, 12:57 PM
SpeedwayCoating's Avatar
Correct on both!
fro
03-24-2005 06:47 AM
Bseriescivic5
09-14-2004 04:13 PM
d_mina
02-20-2004 05:13 AM
quickLSt
02-07-2002 04:49 PM
Quick Reply: Wastegate flange options?
