cutting oil?
Old Dec 8, 2004 | 10:19 PM
self_made's Avatar
Default cutting oil?
What kind of cutting oil are you guys using for ur bandsaws?
Old Dec 9, 2004 | 12:07 AM
ExploitedRacing-HR's Avatar
It depends on what type of system you are using really... If you have to put the oil on it yourself i suggest rapid tap which works excellent for pretty much everything that doesnt require a flooding type coolant system.
If you band saw has a water pump i suggest some Valcool... i personally use VNT 935 coolant... but its also $130.00 for a 5 gallon pale of it while most collants are about $25 for 5 gallons, for a lower budget coolant concentrate try VNT-800 from val-cool. the problem with a lot of coolants out there is most will not work in tap water. it needs to be purified but VNT-800 works in it and is about $12.00/gallon, and 1 gallon of it makes about 15 gallons of coolant.
Old Dec 9, 2004 | 04:52 PM
4drsedaneg's Avatar
Default Re: (ExploitedRacing)
we used to use the mobil stuff at my old work i dont rember the name of it, worked good though, we use this clear green stuff now at my work, its super think and has high lubricity but i dont know how good it is on metal, we cut glass with it on a diamond blade, and the stuff is like 3000 for a 55 gallon drum
Old Dec 9, 2004 | 04:53 PM
4drsedaneg's Avatar
Default Re: (4drsedaneg)
if you put it on your sel i like tapmagic, or cool tool2
Old Dec 11, 2004 | 01:14 PM
self_made's Avatar
Default Re: cutting oil? (VTECNLUDE)
anyone else?
Old Dec 11, 2004 | 04:06 PM
Cool Tool = junk
Old May 30, 2005 | 03:17 PM
RCautoworks's Avatar
What about for a bandsaw, is wd40 enough ?
Old May 30, 2005 | 07:03 PM
blueoval557's Avatar
Default Re: (90blackcrx)
i would not use wd40 on my bandsaw. i use either a high speed cutting oil, or air tool lubricant. i like the air tool stuff because it is clear and you can still see your markings. good luck!
kyle
Old May 31, 2005 | 09:59 AM
CRXDrew's Avatar
Anyone ever hear of using Auto trans fluid? My brother read it somewhere and we used it as cutting fluid when we honed his GSR.
Old May 31, 2005 | 10:19 AM
AceRaceParts's Avatar
Default Re: (CRXDrew)
In our band saw we use Lenox brand "Band-Ade" and for cutting, tapping, and threading we use Castrol Moly-Dee.
XLR8 GS-R
Welding / Fabrication
Dec 19, 2007 07:45 AM
igo4bmx
Jun 13, 2005 05:14 PM
fullblown
Jan 23, 2005 07:26 PM
SPORT INJECTION
Aug 25, 2003 12:15 PM
Sh4rky
Apr 13, 2002 05:13 PM
