How big of a bottle ?
Old Nov 8, 2004 | 04:08 PM
RCautoworks's Avatar
Default How big of a bottle ?
I know the mix of the gas, and I have searched but I really would like to know if I'm gonna be doing exhaust and other misc stuff at home, how big of a bottle should I pick up ?
Old Nov 8, 2004 | 04:37 PM
Fab-Works's Avatar
Default Re: How big of a bottle ? (90blackcrx)
If you are just welding once in a while i think an 80 should do.
Old Nov 8, 2004 | 06:07 PM
Default Re: How big of a bottle ? (anthonycn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anthonycn &raquo;</TD></TR><TR><TD CLASS="quote">If you are just welding once in a while i think an 80 should do.</TD></TR></TABLE>
I definitely won't be welding every day, so 80. How long will that last if I weld about every weekend or so ?
Old Nov 8, 2004 | 07:51 PM
kb58's Avatar
Banned
Then go to a 125; it's not like you can't change your mind you know. Welding shops will usually just let you pay the difference when going to a larger tank. No wasted money. I usually weld a bit every weekend and I use two 125s because it sucks running out of gas and being stuck when the welding store is closed. A backup is great. I'd definitely recommend two tanks regardless, so maybe two 80s would do for you.
Old Nov 8, 2004 | 10:03 PM
Default Re: How big of a bottle ? (kb58)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kb58 &raquo;</TD></TR><TR><TD CLASS="quote"> I usually weld a bit every weekend and I use two 125s because it sucks running out of gas and being stuck when the welding store is closed. </TD></TR></TABLE>
But how long will those bottles last you, weeks, months ?
Old Nov 8, 2004 | 10:22 PM
Fab-Works's Avatar
i would say about 3 weeks maybe more for a weekend welder.
Old Nov 9, 2004 | 06:17 AM
kb58's Avatar
Banned
Guess I'm not a normal weekend welder. Two 125s last me nearly a year. It's pointless asking how long the gas will last you. It all comes down to your actual welding time. Everyone will be different. Even a different setting for post-purge will make a big difference.
Hites!
Honda Insight & CR-Z Hybrid
83
Dec 19, 2009 05:37 AM
kixcrx
35
May 28, 2008 08:43 AM
weiRtech
Welding / Fabrication
14
Aug 3, 2007 02:57 PM
thatonejewishguy
May 28, 2005 08:41 PM
vr6chris
13
Dec 31, 2004 01:01 PM
