Roll-cage welding
Old Jan 2, 2013 | 05:14 AM
NNBD's Avatar
Default Roll-cage welding
Hey.. i'm planning to make my own roll cage, although i've understood that its best to make it out of 25CrMo4 steel since its stronger so I can build it lighter...
But does anybody know the best way to weld this material ? (GTAW)..
Old Jan 2, 2013 | 06:16 AM
all_motor_mike's Avatar
Default Re: Roll-cage welding
tig with er80s-d2..... or thats what i would do.
mike
that-guy's Avatar
all i know is that with chromoly, it has to be tig welded, where with DOM mild, you can still MIG it if you want...use the same practices as you would with welding up a manifold, but you don't need purge gas
Old Jan 2, 2013 | 07:06 AM
NNBD's Avatar
And why is that ? heat input can be the same and backing gas (when needed) can also be applied with MIG
Old Jan 2, 2013 | 08:57 AM
that-guy's Avatar
never knew the exact reason why Chromoly is only Tig'd and never Mig'd, but that is what i have been told by many reputable fabricators, including my next door neighbor who built pro-mod chassis for 20 years
Old Jan 2, 2013 | 09:14 PM
SovXietday's Avatar
It's NHRA rules, mainly.
From what I understand, the rule that chromoly must be TIGed is mainly to keep out shoddy welding work that looks good but has poor penetration. It is much easier to get full penetration with TIG than it is MIG. 7.50 and faster cars must have chromoly cages, not having full penetration on those could be easily catastrophic.
Old Jan 2, 2013 | 10:03 PM
h2.4's Avatar
mike
^^Yes. And what soviet said also. I don't think you're gonna pass cert with chromoly mig'd.
Old Jan 2, 2013 | 11:31 PM
torkh22a's Avatar
if this is your first cage i would suggest not using chromoly, your wallet will thank you.
good luck
Old Jan 3, 2013 | 02:44 AM
that-guy's Avatar
thanks for clarifying...find some DOM and get to work i would say, especially for an unexperienced cage builder. besides, when it's all in, and i assume painted??? nobody will know what material you used
Old Jan 3, 2013 | 07:27 AM
h2.4's Avatar
Mild steel, min wall thickness is .120" for mild steel unless you want your car to get heavy
Old Jan 3, 2013 | 09:01 AM
that-guy's Avatar
typical use of DOM i see is 1.5" OD with .120" wall
Old Jan 3, 2013 | 10:05 AM
torkh22a's Avatar
Nhra tube dia is 1 5/8" minimum thickness .118" so any straight tube can be made of .120 wall tubing but if there is a bend in the tube you need to use .134 wall tubing. This accounts for the stretching the tube undergoes in the tubing bender.
Old Jan 3, 2013 | 04:50 PM
i thought nhra rollcage specs for chromo was 1 5/8" .083" wall?
mike
Old Jan 4, 2013 | 05:51 PM
h2.4's Avatar
I think 10 points can be 1 5/8" but 8 point and down are 1.75". Wall thickness depends on material, diameter depends on the split when going to 10 point or faster you can use the smaller diameter
danteisme
Paint and Body
May 7, 2019 07:26 AM
90Rexx
Welding / Fabrication
12
Aug 19, 2010 02:59 AM
turbospud
Feb 14, 2009 05:26 PM
robbbby
Nov 11, 2007 06:39 PM
filetofit
Jul 2, 2002 02:20 PM
