rad support replacement
i know this question has been answered a million times but my dumbass decided to keep my jack under the rad support for about a half hour came back out and my rad support was bent to **** and every single thread i find this topic on the pictures wont pop up but long story short i need to take my rad support off and replace it if ANYONE has any pictures or info how to do this itd be appreciated im so pissed off at myself for being so stupid lol
ek hatch and my photobucket isnt letting me upload any pictures for some reason. ive seen this done so many times before i just dont know how to remove it.
You have to drill out all of the spot welds to remove it. Do not let anyone try to tell you that you can "BOLT IN" the new radiator support. It needs to be re spot welded or seam welded in.
Do not bolt it back in, your radiator support is a vital part of your chassis' strength. If you do not know how to weld you can hire a mobile welder to come to you and weld it in. Should run you no more then $100 for the amount of work they need to do. I'll see if I can find some links or write ups for it. But please do not bolt it in. That is not safe at all.
its a drag car so its gonna be on and off alot so i figured thatd be the easiest way to do it ive seen alot of cars with detachable rad supports and ok thanks alot man just shoot me a pm with them if you can find any
even though you got it off, it should have been simple enough to just look at it and see what needs to be done. drill out all that you can see, and if it is still attached somewhere, look around to find what you missed. pretty simple stuff, and would actually take longer to look at a diagram to figure it all out than it would just just look at the damn thing and attack
Actually i am curious about knowing how to do this, because i just bought an eg shell that was hit in the front and the rs needs to be replaced. The guy who sold it to me gave me a straight rs that he bought on the junk yard. Can someone share a link or information regarding this. Thanks
Posted from Honda-tech.com App for Android
Who is Mr Robot?
Lots of drilling spot welds... metal prep, and rewelding spot welds.. however this all means dick if the chassis is tweaked
It'd almost be worth it to find a cheap spot welding machine off of eBay... it's seriously worth it because of the time you'll save.
They also make a bit just for drilling spot welds so you don't go through the base panel, makes rewelding the new panel loads easier, as opposed to welding up holes.
First you have to remove that old radiator support and everything else broken/bent then straighten the bent inner fender as best you can with a hammer and dolly and keep test fitting the radiator support until everything is lined up then weld everything back together take your time this is a structural part of your vehicle goodluck man
Dec 1, 2006 10:31 AM
kraven9
13
Sep 14, 2006 03:41 AM
