Machined vac block to weld onto IM?
Old 09-12-2012, 12:55 PM
SovXietday's Avatar
Default Machined vac block to weld onto IM?
Can never seem to really explain this, so pictures instead.
Just looking for the little vacuum block so that I can weld it right onto my manifold. Who makes these? Everything on mcmaster is far too thick.
Old 09-12-2012, 01:08 PM
Vagitarian's Avatar
Default Re: Machined vac block to weld onto IM?
buy a 1/2" thick alum plate, cut to / or premade to a suitable size that works with the number of ports your going to use, drill and tap your holes, weld it on...
If your capable of welding aluminum, you can certainly get and aluminum block and throw a few holes in it, custom to your setup and sizing need
5thgen's Avatar
I usually use a strap of aluminum about .25" thick. I drill the holes, tap them, and weld the plate onto whatever I'm attaching it to.
edit: posted to laaaaate. But what he^ said.
Old 09-12-2012, 05:22 PM
Who is Mr Robot?
wantboost's Avatar
yea 1/2 is way too thick, 1/4 should be fine... just find a piece of 1/4 bar stock and drill and tap it
Old 09-13-2012, 09:57 AM
Andy@AMR's Avatar
If you don't have anything laying around I've got plates cut for this. Just drill and tap how many you want to put in. Send me your address, and I will drop one in the mail for ya. I've got a number of these, I ain't going to sweat missing 1.
Turbo-Honda
Welding / Fabrication
04-07-2006 08:29 PM
-iLLuZioN-B18C1
08-04-2004 06:19 AM
dunkd
06-30-2004 12:25 AM
blackeg
06-05-2004 10:18 AM
SOUNDEFFECTS
11-26-2002 07:23 AM
Quick Reply: Machined vac block to weld onto IM?
