Intercooler piping help needed
Hey guys
Just trying to figure out how to route the hot side intercooler piping. Having issues picturing
how to do this. Stuck on this last piece and could use some points.
I'm thinking of doing a 90 degree bend downwards and going under the front radiator
support.
Let me know what you guys think.
thanks
support.
thanks
If you wanna drop the pipe that low, either go under the support or the fluid reservoir, I personally would just remove the fluid reservoir and go threw that way.
But i guess you gotta loose a little to gain a little lol
Who is Mr Robot?
unless you go backdoor that windshield washer tank has to go, doesn't matter which honda you have
the hot pipe would hang too low if you ran it under the tank
not too familiar with that chassis, but can't you just notch a 3" hole next to that large opening in order to get the pipe in there nice and tight, while also keeping the washer res?
I think it does as well, but if you trim the rad support a bit and place the backdoor high on the intercooler there is definitely room for 2.5" piping to fit through there. Of course this is considering he can/has access to that type of modification.
Otherwise, yeah, dump the resevoir and have fun.
You can relocate the washer resevoir, they sell some that are quite small and can fit in alot of places, but obviously would need to be filled after you use them a little
I have one on my old cvic and switched it over to the passenger side fenderwell, holds about 750ml
Integra_Boi
Welding / Fabrication
Oct 8, 2004 08:43 AM
for a 5th gen lude
