sugaring
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
I am (somewhat futile) attempting to fabricate a throttle cable braket and need to weld gussets on it. the material is a thin SS sheet. i get sugaring and cavitation on the OPPOSITE side of the weld, the bead itself seems to be ok, no burn throughs.
what do i do to alleviate the crap building up?
I think it would be easier to get some angle metal stock or bend some 1/8" AL. But on with the backpurging. Make a jig using U channel metal with capped ends and place the over part getting welded. May I ask what engine this bracket is for?
thanks for the advice. i am fabricating a bracket for the CBR ITBs mated to a D16, using the stock CRX throttle cable. i do not think i can use a angle stock, as the shape of the bracket prevents it. i have also thought about using thicker aluminium stock, but the bracket at its flattest is around 4" long and i fear it will flex regardless.
i'll mock up the cable and the bodies tomorrow.
here are some photos of them without the cable
you can see the original bracket in the first photo, i am extending the length to accommodate the longer adjusting mechanism of the CRX cable.
I have used a setup that looks like a sand blaster cabinet that you pumped argon into to flat odds and ends. It uses a ton of argon though so its really not cost effective if you're paying for it.
EDT.
Are you doing itb turbo?
EDT.
yes, it is a CBR 929RR bodies mated to a custom manifold with a GT28RS turbo.
here is a photo of the discarded bracket with the burn through and the iteration of the bracket with today's final copy which is made out of thicker steel (i'll gusset it still, i think)
the copper is a good trick for welding other materials where you want to prevent the weld from rolling over an edge on a thick block as well. why not just make the bracket in steel and paint it?
aaron
aaron
it is in steel, but it isn't thick enough to resist the flex. the direction has changed (again), with the charge plenum planned i think i'll incorporate the bracket into that instead.
Use copper to bleed some heat off of the part or use an argon closet. If its just a throttle cable bracket grind off the sugaring, paint it, and call it a day.
