driver wheel housing
Old Oct 25, 2012 | 06:42 PM
EFinAwesome's Avatar
Default driver wheel housing
Figured this would be the best section to ask. I'm buying a new radiator support and the wheel housing. I'm just wondering if someone could link me to a video or thread of the wheel housing being replaced. Just gives me a peace of mind before doing it for the first time. I'll continue my search in the mean time. thank you
Old Oct 26, 2012 | 12:17 PM
oversteer_ms's Avatar
Default Re: driver wheel housing
Just to start out, what kind of car are you working with? And what wheel housing are you referring to? Front, rear? I am guessing since you are replacing the radiator/core support, you are doing the front wheel housing/tower.
The more info/pictures you give me the more information I can help you with.
Austin,
Oversteer Motorsports
Old Oct 26, 2012 | 03:09 PM
1993 lx 4dr. Front driver side. Drilled out the spot welds but it still hasn't budged. Only other thing I can think of is drilling larger then the weld. Also I can get the parts for free but if its common to be this big of a pain ill have to buy the oe.
Old Oct 26, 2012 | 07:05 PM
tepid1's Avatar
Don't you have to pull the motor mount support to get that out?
Old Oct 26, 2012 | 09:07 PM
Yeah I'm also taking it out. the spot welds hold them both on along the side closest to the fire wall. Then theres tabs on the mount that hold it to the wheel housing.
Old Oct 28, 2012 | 12:12 AM
If you know you have all the spot welds drilled, and that the body seam sealer is the only thing left in your way, just hammer and chisel to separate it. It should go. Are you replacing just in front of the tower behind the mount? Or in front of the mount. I'm on my cell phone and I can't see the picture as well as on PC.
Old Oct 28, 2012 | 06:19 PM
that section is one peace. It slightly over laps a bit on the tower lip. The spot welds are drilled out but its still solid. Need to get a bigger bit but been busy with other stuff havent tried it yet.
Old Oct 30, 2012 | 02:21 PM
Just in case anyone is following this nail bitter. I got it out and grind it all down to the frame and what not. Now to just find a wheel house that isn't $85
EFinAwesome
Oct 26, 2012 06:12 AM
ryguy2588
Apr 23, 2011 01:55 PM
seen4ever
Jul 1, 2006 03:17 PM
