Divided manifold collector
I have been looking around for collectors, and I can find a ton, but I haven't found any for a divided manifolds. I have made my own manifold before, but never a divided. I am curious to see what you guys are doing for your collectors. Also what processes you guys find to work best for you. Thanks!
Re: Divided manifold collector
I can jump in and figure that much out, but I was hoping for a "I like to use _* angle for a ramhorn, and if I have the space I tweak it" type of response.
I think I did a 13* collector split with like a 10* offset on my manifold. Did it so long ago at this point I don't remember.
Wasn't super easy getting in between on it but I managed. Honestly, easiest collector I ever built.
On the collector, the one side is easy, I can see that. The other side now, that looks like it'll be a bit more technical. Are you welding it from the bottom of the flange? If not, how are you managing to get the seam welded down in there without arcing to the side of one of the walls first?
Ron @ RLD helped a brother out. At the price I got it, it was way more economical to just buy it. I'll be doing the same for all collectors now. If nothing else, just the saw blades, and time saved will be more than worth it! Thanks Ron!
