some 1.8t work ive been finalizing
Old Dec 12, 2007 | 08:29 AM
EdsGTI's Avatar
Default some 1.8t work ive been finalizing
I do mostly 1.8t vw turbo setups, motors, trannys, drag cars. Figured id throw this up here see what you guys thought about it.
Its a zipped up picture album i will post some individual pics here later once i have them (they are on the camera which is dead)
This setup was very close to the one on my car that we made 676whp and 465wtq and went 10.65@137mph in a 2800+lb street car 3rd pass out with the boost staged and the highest boost setting in 3rd and 4th gear was 10 psi lower than the dyno
click the link, check them out and tell me what you think. The turbo pictured is a T3/T67h.o.
http://www.forcefedengineering....html
Old Dec 12, 2007 | 08:34 AM
ivannaciv's Avatar
I like it, looks really smooth. keep up the good work.
Old Dec 12, 2007 | 10:22 AM
all_motor_mike's Avatar
Default Re: some 1.8t work ive been finalizing (EdsGTI)
u did 676whp on a 1.8t an did that 10.6 in a mkIV?? i remember when the 1.8t guys were struggling to get an 11 sec slip.
Old Dec 12, 2007 | 10:27 AM
EdsGTI's Avatar
Default Re: some 1.8t work ive been finalizing (all_motor_mike)
yes that was a mkIV
we are setting the car u for sfwd or whatever the class will be called for the spring and try to butt some heads (obviosly with a much larger turbo setup and revving to ~9-10k, 2450lbs)
Some of the vids from the event.
15" wheels 24.5X8.5X15 M&H i think the car was 2880lbs
drag
http://www.youtube.com/watch?v=8umRGOWTR40
dyno
http://www.youtube.com/watch?v=-ZvBBrzIK10
Old Dec 12, 2007 | 02:06 PM
9 or 10k are u gonna be running solid lifters? (im at work so ill check out the vids later)
mike
Old Dec 12, 2007 | 02:32 PM
miller's Avatar
lookin good fellas
Old Dec 12, 2007 | 02:34 PM
Semnos's Avatar
Very nice.
turboteener's Avatar
Banned
Was kicking somethings around today. How much does one of those engines weigh? What are the short comings? Being a cast iron block I figure they could hold some serious power, but are the heads as good as Honda heads?
I am building a Tube chassis race car and like the idea of a force fed four cylinder. I already have a 4.0 lexus engine to play with, it it is pretty heavy.
Old Dec 12, 2007 | 02:47 PM
EdsGTI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all_motor_mike &raquo;</TD></TR><TR><TD CLASS="quote">9 or 10k are u gonna be running solid lifters? (im at work so ill check out the vids later)
mike</TD></TR></TABLE>
of course, but at 8750 (what we were bashing it to for about a week solid) there were no signs of any issue in relation to valve train movement or float.
The springs could also be shimmed .03" more before getting close to coil bind.
Old Dec 12, 2007 | 02:51 PM
EdsGTI's Avatar
Default Re: (turboteener)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboteener &raquo;</TD></TR><TR><TD CLASS="quote">Was kicking somethings around today. How much does one of those engines weigh? What are the short comings? Being a cast iron block I figure they could hold some serious power, but are the heads as good as Honda heads?
The shor comings of the vw's are the stock small port cylinder heads, they flow worse then a d series honda head.... The major issue is the lift limit on the intake side because of the angle of the valves. They will touch each other when the lift gets to any substantial amount.
The blocks are good. The key way on the crank pulley is gay and sheers, the flywheel only has 6 bolts to the crank and they are 10X1.0mm AND they are an irregular pattern so you can squeeze in 3 more bolts if you wanted to.
The major issue with vw's are the 5 speed transmission not shifting above 7000rpm at any substancial power level, but the 6 speed has held up to my car bone stock with just an LSD, stock axles as well. We are heat treating another box now and working on it.
Modified by EdsGTI at 2:58 PM 12/13/2007
Old Dec 12, 2007 | 02:56 PM
civic.slow's Avatar
* B A N N E D *
Default Re: (EdsGTI)
nice work man, i see that intake manifold too damn. curious how long did that take you?
Old Dec 12, 2007 | 03:55 PM
Turbo-charged's Avatar
Default Re: (civic.slow)
looks good....is the end of your downpipe bead rolled? lol
Old Dec 12, 2007 | 04:24 PM
EdsGTI's Avatar
Default Re: (Turbo-charged)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">looks good....is the end of your downpipe bead rolled? lol</TD></TR></TABLE>
like every other 3" bend i get from atp has a bead roll on it lolol. I figured people would say something about that, f vband, silicone coupleer haha
Old Dec 12, 2007 | 06:43 PM
under_boost's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EdsGTI &raquo;</TD></TR><TR><TD CLASS="quote">
The major issue with vw's are the 5 speed transmission not shifting above 6500rpm at any power, but the 6 speed has held up to my car bone stock with just an LSD, stock axles as well. We are heat treating another box now and working on it. </TD></TR></TABLE>
thats not entirely true. i shifted my 02j 5 speed at 8k daily. oem clutch, ftw. you know this though.
fwiw guys, i think you'll see 2 mk4's next year.
http://s7.photobucket.com/albu...3.jpg
Old Dec 13, 2007 | 04:28 AM
EdsGTI's Avatar
Default Re: (under_boost)
well then your the lucky one. because everyone that was making alot of power was having alot of trouble when drag racing with slicks and bashing gears.
I have 3-5 cars that will be running this year, smallest is a 35r (2 of them) and the other 2 are T67's, one is the setup off my car. But i dont think anyone other than myself is planning to compete.
Old Dec 13, 2007 | 09:33 PM
TommyC83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic.slow &raquo;</TD></TR><TR><TD CLASS="quote">nice work man, i see that intake manifold too damn. curious how long did that take you? </TD></TR></TABLE>
Its an off the shelf part from ross machine
heres a pic on one of our motors
hatchbackhonda
Sep 25, 2004 08:29 PM
rOby
Jan 14, 2003 10:15 PM
integration
Sep 11, 2002 09:30 AM
jinxproof99
May 20, 2002 11:11 AM
archmage
Nov 11, 2001 02:21 PM
