welder outlet
Old Dec 31, 2007 | 03:56 PM
higgunscrx's Avatar
Default welder outlet
i recently bought a lincoln electric mig pak 140 welder. its a 120v welder but i havent tried to use it yet cuz it says that i need a 20a circuit to supply power to it. my question is would i be able to use it on a 15a circuit for welding thin stuff? cuz to buy the wire to run it to my garage outside is gonna cost $140+
Old Jan 1, 2008 | 07:42 AM
DaveF's Avatar
Default Re: welder outlet (higgunscrx)
get used to spending money, it doesnt end.......
Old Jan 1, 2008 | 08:48 AM
robbbby's Avatar
you can use it on a 15a circuit just fine as long as you don't have the output amperage cranked too high.
Old Jan 1, 2008 | 04:21 PM
@irborne's Avatar
plut it into the washer outlet, it's an 20amp
Old Jan 1, 2008 | 04:34 PM
Howitt's Avatar
Default Re: (@irborne)
$140 is cheap, your welder cost atleast $400 you gotta pay to play. Ive spent 1000s on wiring every year in our shop
Old Jan 1, 2008 | 05:06 PM
higgunscrx's Avatar
the garage where i have my tools is detached from the house at the back of the backyard. i didnt know that using a welder would need a 20a circuit. the house is rented so i dont want to run $140 worth of 12gauge wire. mostly i'll be using it to weld sheet metal for body work. i guess the worst that could happen is that the breaker trips.
Old Jan 1, 2008 | 05:34 PM
Syner-G-Racing LLC's Avatar
Default Re: (higgunscrx)
I ran mine on a 15amp breaker with 25' 14/3 extension cord plugged into a 12/3 powerstrip. and the only time it ever tripped was when I welded a long run after a few short runs. I found that if I kept my runs to 4-6 sec I never had a problem. I ended up running a new circuit.
96 GSR-T
Welding / Fabrication
Apr 12, 2010 05:09 AM
wanabericer
Oct 5, 2005 01:02 AM
VTECRXballa21
16
May 18, 2005 07:47 PM
cdog19
Feb 3, 2004 10:39 AM
dropped like its hot
Audio / Security / Video
Nov 3, 2003 07:18 PM
