Transmission & Drivetrain Gearboxes, Differentials, Clutches
first gear & reverse grinding
Old Aug 12, 2009 | 09:29 AM
senpai's Avatar
Default first gear & reverse grinding
What would cause 1st gear and reverse to grind? The other gears shift fine.
Note: It appears that this only happens when the tranny is warm, does that make sense?
Note2: I did install a B&M straight short shifter; however, that may or may not be relevant
Old Aug 12, 2009 | 09:43 AM
Clerique's Avatar
Default Re: first gear & reverse grinding
I'm having the exact same problem, only that my reverse doesn't really 'grind' it just won't go in sometimes.
I highly doubt my reverse gear synchro is bad though.
I think its more related to the 1st gear synchro sleeve that reverse gears uses to engage.
I have my transmission out so I'll tear it apart and investigate.
Old Aug 13, 2009 | 11:04 AM
HangSI's Avatar
New User
I have that same problem! Let me know if you figure anything out.
Old Aug 15, 2009 | 03:31 PM
stevenDAtegra's Avatar
I don't think reverse has a synchro, it has the reverse idler gear that slides up. To stop the grind in reverse, push the clutch pedal down, put the car into 3rd with the clutch pedal still down and then shift into reverse.
Are you stopping completely before putting it into first?
Old Aug 16, 2009 | 05:36 PM
Clerique's Avatar
Reverse has a synchro. It also uses the idler gear, the outer part of 1st gear synchro sleeve and the mainshaft.
I can get into reverse if press the clutch in and out a few times in neutral 1st. I usually put the car in neutral while at a complete stop for a while, when I try to go into 1st to pull off, it doesn't go in, I have to pull off in 2nd gear often.
It doesn't pop out or anything, just doesn't go in.
Old Aug 16, 2009 | 08:37 PM
Garage 808 Hatch's Avatar
welcome to owning honda transmissions. its just a matter of aligning the shift mechanisms before it goes in. shifter back and forth in neutral, then into first. and if going for reverse, and it wont go in. back and forth in neutral, put it in first, then into reverse
Old Aug 19, 2009 | 08:46 PM
teggi's Avatar
yee im having a similar problem
it shifts fine when da engine is cold but as soon as it warms up the tranny wont let me shift in almost any gear and revers grinds a lot
Old Aug 20, 2009 | 12:55 AM
Yeah, the shift change assembly on 2 of my 3 transmissions are really worn in lol. I think it's because the springs on them and cable trannies are so old. 4th gear gives me troubles once in a while but I fixed it now swapping in one of my newer shift change assemblies
Old Aug 20, 2009 | 06:08 AM
Clerique's Avatar
I was thinking about this, cause my Synchros are in good condition (at least when I put them in last december).
Cause mine don't grind, just doesn't go in.
Old Aug 20, 2009 | 08:33 PM
teggi's Avatar
i replaced da tranny fluid and now it works fine
warm or cold
no grinds no stiffness either
Bond
Jan 31, 2005 07:14 PM
JDM_Type-R
Oct 23, 2003 06:10 AM
maxpsi
Jun 16, 2003 01:40 PM
b20civic
Sep 8, 2002 11:33 PM
