Transmission & Drivetrain Gearboxes, Differentials, Clutches
Possible ISB Problem
Old Feb 9, 2010 | 04:27 PM
Jimster480's Avatar
Default Possible ISB Problem
What are the symptoms of a bad Input Shaft Bearing? Where is it located, and how long will it last? Because I put in a tranny I got off of craigslist and it makes a horrible gear grinding noise when its under load (slowing down in 1st/2nd gear) or accelerating full throttle. It drives fine and the clutch grips fine it just makes this noise. And its not when going into the gears, it shifts like butter. So I'm just wondering if its the input shaft bearing, and how hard it would be to replace this.
Old Feb 9, 2010 | 04:38 PM
Marxx 1982's Avatar
Default Re: Possible ISB Problem
Idle the car , step on the clutch. than listen while you let it out , if it starts whirring , its mainshaft bearings..
Old Feb 9, 2010 | 04:55 PM
Jimster480's Avatar
it doesnt whir when you let it out. It grinds when under load
Old Feb 11, 2010 | 06:47 AM
Jimster480's Avatar
any more input here?
Old Feb 11, 2010 | 07:31 AM
sanman000719's Avatar
have you ripped it apart yet man and checked it all out or drained it and inspected the oil from it?????
Old Feb 11, 2010 | 07:38 AM
Jimster480's Avatar
no i have no idea how to take the tranny apart. Or if I take it apart how to put it back together lol
Old Feb 11, 2010 | 07:55 AM
e either till 2 weekends ago man i followed a tear down thread, and couldnt beleive how easy it was.
my tranny has been making a metal on metal squealing sound like a bearing going out so i took it out ripped it apart, and found all kinds of goodies inside it (broken gears,metal peices).
Old Feb 11, 2010 | 07:57 AM
https://honda-tech.com/forums/transmission-drivetrain-127/b-series-transmission-teardown-rebuild-tutorial-2443459/
Old Feb 11, 2010 | 03:03 PM
Jimster480's Avatar
damn. Well after i replace this tranny with another one (if that one is good) then maybe ill take this one apart. Thanks for the link.
Jimster480
10
Feb 9, 2010 05:54 PM
theappe
17
Jan 13, 2010 06:09 PM
CalhounBoi
13
Feb 28, 2007 06:23 PM
Loki12
Aug 7, 2005 09:36 AM
transitions
Aug 6, 2005 06:48 PM
