Grinding noise when clutch pedal released any gear + neutral
Got a shell and an Ls swap for a 90 Integra manual
I put the car in reverse for the first time and let the clutch out slowly only to hear a grinding noise from the engine bay
I immediatly pressed the clutch back in then tried first gear.... same thing put it in neutral to let the car idle and I still got the grinding noise...
Only thing ive seen relatively close to this is on google and it was a vw that ended up having a bad cv joint
thanks for any help thats given
Re: Grinding noise when clutch pedal released any gear + neutral
oh thought possilbly bad clutch so I had a buddy give me his old one spent yesterday droppin the trans and replacing the clutch/inspecting had an ebay clutch and one of the plucks was eaten up.
replaced clutch... same problem
oh and it doesnt move
