Transmission & Drivetrain Gearboxes, Differentials, Clutches
Differential gone?
Old Feb 21, 2010 | 02:20 PM
MrMug3n's Avatar
Default Differential gone?
driving the car makes a winning noise while in gear, when in nutral you hear all kinds of clicking and clanking. so i buy a new clutch kit, fly wheel, bearings ext. and after all the labor i still have the same winning and clanking. also, i noticed there was metal shavings in the tranny fluid and when i push in the clutch there is a delay on when the clicking stops. this is why i think its the diff. any thoughts / suggestions? should i rebuild or just buy another?
Old Feb 21, 2010 | 03:43 PM
wantalude's Avatar
Default Re: Differential gone?
there are probably teeth from a gear floating around in the bottom of your tranny. while the gears are spinning the pieces are bouncing around and making noise. you push in the clutch, the gears slowly stop spinning hence the delay in the noise stopping
Old Feb 21, 2010 | 04:42 PM
MrMug3n's Avatar
so your saying its not the diff but the gears? even though ive had no grinding or slipping at all?
Old Feb 22, 2010 | 01:34 PM
MrMug3n's Avatar
anyone?
Old Feb 22, 2010 | 03:59 PM
jdmcivicracer89's Avatar
tear it open and find out its not too hard.
Old Feb 24, 2010 | 09:19 AM
ryddlebox's Avatar
Dude just take it out and have a look inside. But that does sound like broken teeth. A trans doesn't necessarily grind or slip out just because the teeth are screwed. your synchos could still be fine HENCE: The nice smooth shift with nasty sounds. Just take it out do a lil research on the break down and see. If your'e not mechanically inclined just dont take the gearsets out, when you take the case off you can see everything.
Old Feb 24, 2010 | 01:47 PM
Nealoc187's Avatar
From: West suburbs of Chicago, IL formerly Kalamazoo, MI
what you are describing is not a differential problem, pressing in the clutch would not cause a differential problem to slowly quiet down and go away.
gears don't "slip" so not having any slipping does not mean anything, and you can have broken gear teeth without any grinding, so not having grinding doesn't necessarily mean anything either. you need to take it apart and find out what's broken, your description is not sufficient for us to tell you 100% what's wrong with it. either replace it or have it rebuilt.
HondaLuv3r4Life
Dec 11, 2013 09:24 AM
MrMug3n
Feb 22, 2010 01:38 PM
jimbrown
Jul 17, 2007 12:35 PM
TiredToyotaDriver
Jan 14, 2006 07:26 PM
Pinhead
Feb 4, 2002 12:37 PM
