Transmission & Drivetrain Gearboxes, Differentials, Clutches
Fill bolt stuck
Old Sep 25, 2010 | 02:31 PM
1sthonda's Avatar
Default Fill bolt stuck
I just got my first honda. 5-speed 1993 civic VX 320k miles. I´m changing all the fluids and giving it a tune up. I don´t know the last time the tranny fluid was changed so I went to the dealership and got the right fluid. The problem is the fill bolt is stuck.
I was able to loosen the drain bolt with almost no effort. I didn't drain it because I didn't want to be up the creek without a paddle. However the one drop of oil that seeped out of the fill bolt was clean and clear.
I´m the 3rd owner and I know the 2nd owners never changed the transmission fluid. They had it for about 40k miles.
I´ve only changed the transmission fluid on AT cars. Is it normal for the transmission oil on MT to remain clean and clear? It look and smelled brand new.
What should I do? I don´t want to go to a mechanics and spend $70-90 to have someone remove two bolts for me.
Old Sep 25, 2010 | 02:33 PM
kaiba's Avatar
Default Re: Fill bolt stuck
2nd option. Filled from the speed sensor hole.
Old Sep 25, 2010 | 02:45 PM
1sthonda's Avatar
I have no idea what that is. Is there a picture? Can you explain?
Old Sep 25, 2010 | 02:58 PM
kaiba's Avatar
See the hole on top. That what it should look like after the sensor is removed.
Old Sep 25, 2010 | 02:59 PM
kaiba's Avatar
Picture with sensor still on.
Old Sep 25, 2010 | 03:54 PM
1sthonda's Avatar
Can I over fill it if I do it like that? 1.9l is what the owners manual says. I have 2 liters, so I guess I can just limit one of them by a 100m
Thanks!
Old Sep 25, 2010 | 04:52 PM
1sthonda's Avatar
Whats the best way to remove the sensor? Do I need to get a new gasket after I remove it?
Old Sep 26, 2010 | 10:40 PM
cbustuner's Avatar
No new gasket needed. It's only mounted by one 10mm bolt,Unplug it, remove the bolt and wiggle the sensor out. I don't think I have ever filled any Honda I've owned up using the fill hole. I always do it this way.
Old Sep 27, 2010 | 08:39 AM
1sthonda's Avatar
Thanks that did the trick!
Old Sep 27, 2010 | 01:35 PM
Mista Bone's Avatar
D Tranny Guru
using the full 2 quarts/liters won't hurt anything.....
Also you need 10w30, Honda doesn't sell that.
Old Sep 27, 2010 | 08:27 PM
1sthonda's Avatar
I picked up the Honda Manual Transmission fluid for like $8 a liter. I was going to just put it 10w30, but a mechanic told me that every honda transmission that he worked on that failed was because it had 10w30 fluid in it, and now Honda Brand stuff.
Was this guy full of BS?
Old Sep 28, 2010 | 07:01 PM
Mista Bone's Avatar
D Tranny Guru
Yep, he's full of it.
88-95 Civics/CRXs, millions mades, spec fluid is 10w30 motor oil.
The latest Honda MTF is too thin for the older transmission. The first generation of the Honda MTF did ok.
bad 91 teg
Feb 1, 2011 04:09 PM
GSRWSU
Jun 25, 2009 03:26 PM
thanh4o8
Sep 17, 2008 12:06 PM
ocdcivic
Dec 11, 2004 10:11 AM
Kyles ej1
Sep 23, 2004 04:41 PM
