Transmission & Drivetrain Gearboxes, Differentials, Clutches
What vss to use in cable transmission in a hydro car
Old 09-08-2010, 10:03 AM
sicknastyb17's Avatar
Default What vss to use in cable transmission in a hydro car
I bought a crx that has a b20vtec with a cable s1 trans but the owner before converted the car to obd1 and put a dc gauge cluster in the car. This means the car has a electric vss and not the cable one. The probelm is if you remove the vss and turn by hand or drill the gauge on the cluster works, but if I install the sensor and drive I get NO read from tranny on the gauge or datalogging meaning the speedo gear is not touching the vss gear. I was wanting to know if there is a electric vss to use that will engage the speedo gear in the tranny. Thanks
sicknastyb17 is offline
Old 09-08-2010, 03:36 PM
Default Re: What vss to use in cable transmission in a hydro car
Thanks everybody. I got it. Thanks
Old 06-12-2019, 07:18 AM
What did you do to fix it im having the same problem?
Dee9222 is offline
Old 06-16-2019, 09:57 AM
Can anybody help me with this problem it would be greatly appreciated
Dee9222 is offline
daigo
Engine Management and Tuning
03-14-2013 08:01 PM
hoga113
03-08-2013 04:32 PM
hoga113
03-06-2013 02:16 PM
RACEPAK
10-30-2011 06:16 PM
ronwilliams
05-26-2011 09:53 PM
Quick Reply: What vss to use in cable transmission in a hydro car
  • Ask a Question
Question Title:
Description:
