Transmission & Drivetrain Gearboxes, Differentials, Clutches
clutch for spring
Old Dec 17, 2010 | 07:38 PM
Ghost Eg's Avatar
Default clutch for spring
where does the spring behind the hydro clutch fork go?? I forgot the exact name for the spring but its basically the spring that makes the tension so the slave has something to push back and forth on.
Old Dec 18, 2010 | 07:12 AM
unusual71's Avatar
Default Re: clutch for spring
are you taking about the one that holds the fork in place against the pivot?
Old Dec 18, 2010 | 07:21 AM
David @ Synchrotech's Avatar
The hydro clutch fork does not use a return spring like the cable model. The spring only holds the fork on the pivot ball.
GEN2 LS
Feb 20, 2014 04:13 AM
devious
Jul 24, 2010 07:11 PM
redDAinteg
Jan 29, 2007 03:23 PM
lude1888
Apr 23, 2006 06:39 PM
blkwidow420
Apr 25, 2004 03:18 PM
