Transmission & Drivetrain Gearboxes, Differentials, Clutches
Does my clutch need replacement?
Old Jan 11, 2011 | 02:01 PM
dgerej2's Avatar
Default Does my clutch need replacement?
The clutch is quite stiff and it squeaks at times. I have never replaced it. It is possible this is the original clutch. (I am not the original owner) My car has 110k miles. It this thing toast? I will be researching in the mean time.
Why is my clutch so messy? The problem is getting worse.
This doesn't seem right. I have never bothered looking into it. Can anyone show me the piece that appears to be missing. Thanks
Old Jan 11, 2011 | 02:08 PM
94EG8's Avatar
Seagull Management
Default Re: Does my clutch need replacement?
Define stiff. Mileage is a really poor indicator for clutch wear, i've seen stock honda clutches last about 300,000 miles and i've seen some destroyed in 10,000 miles. It mostly depends on how it was used/abused.
Old Jan 11, 2011 | 02:23 PM
dgerej2's Avatar
Stiff isn't a good expression. It just seems to require more force that normal in my oppinion.
Old Jan 12, 2011 | 01:11 PM
igorka_91's Avatar
You can clearly se that youre master cylinder. HOw ever you call it. Is leaking. I would replace it and bleed the crap out of ure system.
Old Jan 12, 2011 | 01:46 PM
94EG8's Avatar
Seagull Management
Yep, couldn't see pic before.
Old Jan 12, 2011 | 03:49 PM
mattdeeds's Avatar
Thats def a MC needing to be replaced... May not even need a new clutch after you fix that and bleed the hydraulic system right
Old Jan 12, 2011 | 05:36 PM
igorka_91's Avatar
Mines been leaking for over 2 years since i had owned my teg. Ill get around to changin it one day.
Old Jan 12, 2011 | 07:59 PM
dgerej2's Avatar
"Replace the clutch master cylinder and then bleed the hydraulic system. The job is very easy if you buy the $4 One Man Brake Bleeder tool from Harbor Freight Tools."
I got some help on from a cc member named RonJ. Thanks for the comments, you guys were on track.
03djmAccrd
20
Jul 25, 2010 05:16 AM
Ben_si
May 17, 2005 07:32 PM
tyflip2
Jul 17, 2003 01:37 PM
alfaaay
Apr 4, 2003 08:47 PM
Accord_Munch
Dec 17, 2001 12:33 PM
