itr countershaft vs b16 countershaft
Are there any differences in the 95-97 spec jdm itr countershaft and 00 si countershaft? Reason I ask is I plan on running a type r lsd with a 66 teeth ring gear and want to make sure that my 15 tooth si countershaft will work. From my reasearch a 95-97 itr and gsr ring gear is 66 teeth and their countershafts are 15 teeth, which gives it a 4.4 final drive. So will my 15 tooth b16 countershaft work? And I'm a noob at this, is the countershaft the same as a pinion? Thanks for help
RTW DC2R
02-26-2003 10:13 AM
b16, counter, countershaft, countershafts, difference, engine, gsr, honda, itr, jdm, main, shaft, teeth, type, use
