What is the best method to remove surface rust from metal?
Old Oct 31, 2006 | 08:07 PM
professorman's Avatar
Default What is the best method to remove surface rust from metal?
Hi all!
I just bought a used hitch, but it has alot of surface rust on it. Whats the best/most cost effective way to clean off all the rust?
I was thinking of sand-blasting. Anyone have any idea how much it might cost?
What other methods do you guys suggest? What type of paint should I spray it with when I am finished to prevent it from rusting again?
Old Oct 31, 2006 | 10:02 PM
TheBandit's Avatar
Sandblasting would be the easiest thing to do. Then just paint it with your ordinary black spraypaint and you should be fine for quite a while.
-Michael-
Old Oct 31, 2006 | 11:19 PM
VRD^don's Avatar
Default Re: (TheBandit)
hook up a wire wheel to your angle grinder.
Old Nov 1, 2006 | 12:52 AM
sleepinEP3's Avatar
Default Re: (k_motor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k_motor &raquo;</TD></TR><TR><TD CLASS="quote"> wire wheel </TD></TR></TABLE>
Old Nov 1, 2006 | 05:36 AM
Running925's Avatar
Default Re: What is the best method to remove surface rust from metal? (profroopchan)
Sand blasting that will take about 10min. & it will be done to perfection, if you use a wire wheel, you could spend hours on it if it's pitted at all.
I run a powder coating shop out of my garage & i did something like that for someone b4, blasting costed them 20 bucks & powder coated it for 50. I'm sure you could find someone local to you to blast it for you & then you could just paint it if you wanted.
Old Nov 1, 2006 | 06:46 AM
MidShipCivic's Avatar
How do you clean the metel after sandblasting?
Old Nov 1, 2006 | 07:10 AM
Dangger's Avatar
sand blasting for 20 buck!?!?
you'll be dumb not to go with this route..
you can use pure acetone or alcohol to clean the metal..
Old Nov 2, 2006 | 11:47 AM
Default Re: What is the best method to remove surface rust from metal? (Running925)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Running925 &raquo;</TD></TR><TR><TD CLASS="quote">
I run a powder coating shop out of my garage & i did something like that for someone b4, blasting costed them 20 bucks & powder coated it for 50. I'm sure you could find someone local to you to blast it for you & then you could just paint it if you wanted.</TD></TR></TABLE>
Was that your price $20 for sandblasing, or thats the normal price?
Old Nov 2, 2006 | 11:53 AM
Howitt's Avatar
the guy I use would cost about $10 to blast and prob about $50 total with it painted black with some industrial paint or bout $60-70 powder coated
Old Nov 2, 2006 | 07:36 PM
Running925's Avatar
thats what i would charge but thats about going rate. I primarily do powder coating but i offer the blasting service to those that are unable to prep their own materials.
media blasting it will take it right down to metal
Old Nov 3, 2006 | 12:21 PM
standbackimapro's Avatar
If you have a electric angle grinder or an air angle grinder, get some of those 3M pads, grind it all off
there was alot of surface rush on a lift at work, and i just grinded it all off with that... easiest
Old Nov 3, 2006 | 12:26 PM
SteveoBA8's Avatar
Default Re: (standbackimapro)
4inch angle grinder will take care of it all, then rattle can that ****
Old Nov 6, 2006 | 06:26 PM
Hump-Free's Avatar
a small sand blaster. It will pay off in the long run if you buy one. I used mine once a month.
thecruzs2007@yahoo.com
Nov 13, 2010 05:48 PM
JDM JEFFREY
Paint and Body
10
Dec 12, 2009 02:13 PM
huge230
Paint and Body
May 26, 2009 06:20 PM
JDMJNKY
Suspension & Brakes
Jun 4, 2007 11:40 AM
sircrxracer
Jan 5, 2005 01:36 PM
