Starter not disengaging in time...
2005 EP3, stock powertrain.
On cold and humid mornings, there is a split second shreek from the engine area when starting the car. I'm fairly certain it's the starter gear not disengaging in time (bendix gear?); very similar to this vid:
http://www.youtube.com/watch?v=Bmqkq2zqQqo
- I'm hoping the bendix gear area just needs to be cleaned and lubricated?
Is this a easy thing to accomplish, what's involved?
- What if the starter needs to be replaced, is it accessible on it's own, or do other parts such as the axle etc need to be pulled to access/replace it?
Thank you!...
Thank you!...
Re: Starter not disengaging in time...
I've taken apart several honda starters. They are not that crazy. Unfortunately on the K series engines getting to the starter is a real pain in the ***. So in my opinion if you are sure it's a starter you might just want to invest in a new starter and just replace it... Since you have to go through a lot of hassle to get it out I'd hate to see you take it all apart then put it back together to have no fixed it. . .
If you don't want a different starter, just carefully start unbolting and pay attention and you'll be just fine.
sloop
11-30-2002 11:59 AM
05, acura, civic, cold, disengaging, disengauging, ep3, honda, motorcycle, remove, replace, replacing, rsx, starter
