Honda CR-V & Element 2WD & 4WD Element & CR-V
suspension problem
Old Oct 20, 2011 | 03:27 PM
decode33's Avatar
Default suspension problem
My 1998 crv is getting old with 260K kms but is still strong and running with one click start and no check engine light for the six years I have owned it. My problem is that when on the higway the car sways up and down like a swing (especially notable at really high speed). Also at 30 kph the car has a slight vibration which cures it self as speed increases, and when braking from a good speed there is vibration. My suspect is the lower ball joints. Things I have done so far are changed the timing belt and valve adjusted, water pump, radiator cleaned, changed both upper control arms with upper ball joints attached, new front struts, new front both axles.
GGMK
Suspension & Brakes
Mar 3, 2012 09:06 PM
Sardawg
Dec 12, 2005 01:00 PM
all_motor
Nov 23, 2005 02:21 AM
veganej
Oct 9, 2005 12:29 PM
N21
Sep 3, 2003 11:02 AM
