blinking d after valvoline trans flush
2006 Element 93,000
So I just paid off my Element, decided to get tires rotated, trans drained & filled. It seemed to shake after 70 mph next day but it was windy and I didnt know if it was tire rotation.
No problems for a week then blinking D light.
Supposedly Valvoline Max Life is ok for Honda but web sources say otherwise. Hoping for a fix that doesnt break the bank. Dropping off at the Dealer later for diagnostics.
Any experiences here?
Re: blinking d after valvoline trans flush
you should only use oem honda atf for the trans, a lot of V owners here(including ME!)
got into trouble or had issues w/ their tranny after using non oem atf... replace it asap!
drain and fill it for couple of times or if you could get to any shop that purges the tranny
fluid much better, but youll end up using lots of atf so buy a box online to make it cheaper!!
hth..
G/L!
hth..
G/L!
you should only use oem honda atf for the trans, a lot of V owners here . . . got into trouble or had issues w/ their tranny after using non oem atf... replace it asap! Drain and fill it [three] times . . . . but you'll end up using lots of atf so buy a box online to make it cheaper!! hth.. G/L!
One final caveat: under no circumstances should you allow anyone to "power flush" your transmission using any sort of pressurized equipment.
Thanks, Honda dealer it said needed a switch replaced in tranny and it's covered under Honda care. Refilling with Honda trans fluid. Will ask them about drain & fill 3x if that's really necessary! Hoping for no more transmission issues...
If you have Honda do it be sure you tell them you used a non-spec fluid, and you need to replace all of it.
fitseries3
Transmission & Drivetrain
57
10-09-2012 05:00 PM
