Honda CR-V & Element 2WD & 4WD Element & CR-V
B20b compression
Old Feb 11, 2013 | 03:46 PM
crv_driver's Avatar
Default B20b compression
Just over 200k miles my compression is between 121 and 126 in all 4 cyilenders.....is this bad? I read its supposed to be 135 to 175...
Old Feb 11, 2013 | 04:25 PM
shermanyang's Avatar
Default Re: B20b compression
As long as they're all the same it's good. Expect a little compression leak @ 200k miles due to warn parts. I'd also try a different compression tester as well just in case.
Old Feb 11, 2013 | 04:32 PM
LDForget's Avatar
thats a bit low but as long as theyre all close you wont get any drivability issues. Was the engine at operating temp when you tested it?
Old Feb 11, 2013 | 04:44 PM
crv_driver's Avatar
i drove it about 2 miles to the orileys , it was a cold day.. the spark plugs were ouchie.. lol.. im just trying to deceide when i should change out my motor... maybe i can pull another 50k miles out of it.. new timing belt and water pump and tensioner....
Old Feb 11, 2013 | 04:46 PM
Also...did you 'floor' the gas pedal and leave it floored while cranking the car when compression testing? I remember not doing this once and I got really low numbers.
Old Feb 11, 2013 | 04:48 PM
crv_driver's Avatar
no i dident at all, i just turned it over for about 6 second... actualy to be honest im trying to deceide if i need a motor or if it can wait cuz its either buy motor or buy ksport coilovers lol
Old Feb 11, 2013 | 05:02 PM
LOL!! So you didn't even properly test your compression. This is what I normally do:
1) Remove ECU fuse
2) Remove all spark plugs
3) Screw in compression tester
4) Floor gas pedal and keep it floored for the duration of the test
5) Turn key and crank motor, I normally count about 10-12 cranks per cylinder
Old Feb 11, 2013 | 05:46 PM
crv_driver's Avatar
yeah i guess not, im still new to all this stuff.. haha.. but im learning... thank you. ill try this tomarrow and get back to you with the resluts
jdmitrna
Jul 5, 2008 04:48 PM
hondaaccord94
Nov 29, 2005 07:43 PM
pip9
Aug 17, 2004 04:19 PM
shortyz
Jun 24, 2002 11:15 AM
nugget8000
Aug 13, 2001 09:51 AM
