Honda CR-V & Element 2WD & 4WD Element & CR-V
starting problems
Old Jan 23, 2013 | 02:37 PM
Babybwoy's Avatar
Default starting problems
my 2003 Honda crv is taking long to strt?
Old Jan 24, 2013 | 05:47 PM
SirFerret's Avatar
Default Re: starting problems
Is it winter where you are? If so, cold weather always makes starting take a bit longer. It takes my 2000 CRV a second or two longer to start during cold days compared to warm ones.
Also, check if your battery is good. 9/10 times it is the culprit for starting problems.
Old Jan 25, 2013 | 04:03 PM
FasterScooter's Avatar
Icon2 Re: starting problems
B, a little more info/history is needed; how long have you owned the rig? is this a new issue? how long does it crank before starting? Does it seem to crank slow? Once it starts does it seem to run smooth? Do you smell gasoline when it cranks? Recent work done on it? Any additional info would be helpful to the folks on this site. Mo is betta
Old Jan 26, 2013 | 08:08 AM
bigballer8526's Avatar
try a group 35 battery??
dthor68
May 4, 2018 10:33 AM
03ep3sicivic
Jun 28, 2009 08:05 AM
wintermute
Feb 12, 2007 12:09 PM
vietnogi
Jan 31, 2006 03:39 PM
Sticky Tires
Feb 12, 2003 01:18 AM
