Honda CR-V & Element 2WD & 4WD Element & CR-V
Stuttering issue
Old Jan 29, 2013 | 06:49 AM
dueces's Avatar
Default Stuttering issue
Hey guys, I was driving to work this morning, and my car started stuttering, HARD. It got to the point where the car barely wanted to move, and the check engine light started flashing. Besides basic tuneup stuff like plugs, wires, cap and rotor, any suggestions on where to start looking for an issue?
Thanks
John
Old Jan 29, 2013 | 09:16 AM
FasterScooter's Avatar
Default Re: Stuttering issue
Retrieve the check engine code(s) would be the best place to start.
Old Jan 29, 2013 | 09:40 AM
dueces's Avatar
Check engine light is not staying on. i dont think there will be codes to retrieve. also the car is sitting at my work and i dont think i can get it to a parts store. i started the car over my lunch period, and it ran great until it warmed up. then it started stuttering real bad again. thats leading me to believe its internal to the disty.
Old Jan 29, 2013 | 04:40 PM
dueces's Avatar
Well after work I finally got to check it out, turns out the rotor inside the disty cap was completely loose! No bolt to be found anywhere that should have been holding it in. New cap and rotor and now all is well.
Old Jan 29, 2013 | 04:53 PM
Danielsb20crx's Avatar
there should be a lil scerw in there you should check your pickups because there magnetic and if you hit a good bump that thing will bounce around in there
Old Jan 29, 2013 | 05:14 PM
dueces's Avatar
Sorry I should have been more clear. There wasnt a bolt in there, I replaced the cap and rotor AND the screw, so it's all good now.
I did just take it for a test drive, and it still stutters if I take it up in the rpms, so I have more investigating to do
91accordflow
Jun 6, 2009 05:12 PM
xkevox
Jul 23, 2008 05:18 PM
dogg2k78
Aug 17, 2006 03:18 AM
bleebdat
Jan 8, 2003 04:56 PM
