Will these wheels fit?
Mazda speed wheels 18x7.5 with a 55 offset all around?
Tires are 225-40-18 but will probably buy bigger tires. My main concern is will they bolt up?
Re: Will these wheels fit?
PCD is the same, offset is pretty high though, may need spacers to keep them from rubbing on the inside at full lock. 45offset would be better
Yes but stock CR-V wheel is only 6.5" or so, not 7.5".
Two wheels identical to each other apart from width will sit differently even though they have the same offset.
U should be fine your Inner Clearance:-19mm and Outer Position: would extend +19mm
My 18's used to be 18x9.5 +38. My inner clearance was: -27 and outer position was: +61
Whats hub size of the mazda wheels? Do u plan on lowering/raising your crv? Tire size is ok but if they are going bald u should get 215/45 .
