Honda CR-V & Element 2WD & 4WD Element & CR-V
00-01 engine difference?
Old Jan 7, 2013 | 11:06 AM
flanders43's Avatar
Default 00-01 engine difference?
My girl has a 01 Honda crv and the motor just let go tiger Japan has the 00 motor for about 350 cheaper than the 2001 engine trying to figure out the main difference between the two motors as to why the price would vary so much
Old Jan 7, 2013 | 04:18 PM
go-part's Avatar
Default Re: 00-01 engine difference?
Maybe one has more miles on it, or the supplier just paid a different price for that motor due to its age. Im not seeing any changes in those two years due to the fact that they both come from the same generation crv.
Old Jan 7, 2013 | 05:37 PM
94EG8's Avatar
Seagull Management
'99 - '01 are the same. Also Tiger has an absolutely horrible reputation. I'm not going to say buy from Hmotors and no one else, but I'd buy from a lot of other importers before I bought from Tiger.
Old Jan 7, 2013 | 10:37 PM
crvfan's Avatar
Are there any importers local to you, i'd try that first. We have a couple near me.
Old Jan 8, 2013 | 12:35 AM
r3devi7's Avatar
00 and 01 are a B20z were as 97-99 is B20B. B20z is more compression, different intake manifold, most noticeably the large "box" on to of the manifold. Has like 10hp more than b20b, but also is more common to have the "tight valve random misfire" problems.
Old Jan 8, 2013 | 02:00 AM
94EG8's Avatar
Seagull Management
'99 - '01 is B20Z
'97 - '98 is B20B
All JDM CR-V engines are stamped B20B low compression or not.
Old Jan 8, 2013 | 06:30 AM
flanders43's Avatar
Thanks for the info I didn't think there was a real big difference this will be my 4th motor fom tiger never had a issue
Old Jan 8, 2013 | 08:13 AM
94EG8's Avatar
Seagull Management
Btw, the B20Z has 20hp over the B20B, not 10.
dwfronk
Aug 21, 2012 02:55 PM
jsb996
Southern California
Sep 4, 2011 01:32 PM
hb_racer
May 20, 2004 02:51 PM
GSRaCeRbOI
Mar 29, 2002 10:46 PM
