- 3G Insight struts/suspension
- Weldable AN Fittings for Custom Fuel Line on 2019+ Insight?
- No manual frustration
- what should i look for when buying a used 2011 crz auto with 200k+ miles?
- MAF sensor recommendations
- Are my ball joints going to fail on me?
- A/C compressor and fan, radiator fan - not working
- Honda Insight 2009 P15C3 an P15C4 codes
- AC Problem with 2019 Insight
- CEL Fix for no CAT
- 2011 Honda CRZ EX Subwoofer and amp install
- location of 2011 CR-Z EVAP sensor
- AC Pressure sensor part# issue
- Headlight help on 2011 crz!
- Removing door panel to replace speaker
- First gen Insight (2000-2006) pistons + rings. NLA everywhere
- 2010 Honda Insight CVT Pan Gasket
- 2011 Insight new IMA installed but blowing fuses
- Should i buy this?
- 2011 CR-Z vtec spool solenoid wiring
- 2022 Honda Insight EX-Add ons, cameras, trim, spare tire, etc.
- Pedal adjustment for 2022 Honda Insight?
- 2011 crz won't start
- Supercharged CR-Z ....
- 2020 Insight Starting Problems
- Complete K-Swap CR-Z Guide
- 2011 CR-Z Aftermarket Subwoofer?
- The Alarm is stuck on and I can't get it off
- Chemical Smell?
- CRZ factory rear sway bar.
- Roof Rack
- Hybrid OBD2 Codes
- 2011 CR-Z K24Z7 swap
- Any tips on installing aftermarket speakers + subwoofer on 2011 Insight?
- LTO swaps on 1rst gen insights anyone in progress or care to discuss.
- Suggestion on change of fuel injectors of Honda insight 2012
- Removing a door handle from a Honda Insight
- Websites for styling
- Bluetooth Audio Issues in 2020 Insight
- Questions about 2019 Insight I can't find answers to
- Driving Mode
- Front Parking Sensors
- Insight 5 lug disc rear conversion.
- Stock 2000 insight dyno graph.
- 2001 honda insight cvt - goes into gear but won't move
- Bluetooth outdated in 2011 Insight
- Outdated Bluetooth in 2011 Insight
- Won't go into sport mode
- My new daily 2000 Honda Insight.
- Just purchased an HPD CRZ!
- 2019 Honda Insight price - what did you pay?
- I need you guyss help for a used car purchase (crz)
- 2011 Insight Tire options
- Brake pedal dead zone
- 2000 Honda Insight
- 2019 Honda Insight hybrid - LX / EX / Touring - What to get?
- Srs unit
- remove screen in steering wheel?
- Resurrected my old account, to share and inquire about my new 2010 Insight
- Insight 2019 question
- honda insight 2012 blows the 53 fuse
- Buying a used 2011 CRZ
- Crz hitch?
- torque specs
- Honda Clarity AVAS . Is it controlled by a fuse or cord.
- Honda Insight 2001 Possible Stuck Gas Gauge
- Buying A Used CRZ and IMA System Warning
- Troubleshooting: 2013 Insight leaking coolant
- Crz engine
- 2004 Honda Insight CVT code P0141
- 2011 Honda CRZ horn button not working
- insight k20 conversion harness
- 2011 Honda CR-Z motor power inverter poops out at 66k mi
- coolant temp wiring
- can i remove cr-z front license plate holder without damaging bumper
- looking to buy 2011 crz or 2012 crz want input
- 2010 Insight transmission pan gasket
- Jumpstarted my insight, it turned on but Car died later
- auto stop beeping noise, honda insight 2010 model
- Long-term storage of a 2013 CRZ
- 2000 insight rear tire change
- 2010 Honda Insight - Low Beam stay always On
- AC cuts off and on
- New CR-Z Owner
- CR-Z and a pit bull - 5,200 miles to Utah and back
- Help please????
- Installing Aftermarket Amp and Subwoofer
- Blue tooth audio streaming add-on.
- Disabling GPS
- Home / News / 2018 Honda CR-Z: It Might Finally Be What We Wanted All Along
- 1G Insight brake master cyl alternative/upgrade possible?
- Build thread-1G Insight w/L15a Fit A/T ultimate commuter
- Insight control arm mod for RSX knuckle
- Need More POWAHHHH! 1998 CRV
- Starting and Idle problem
- J Series Insight
- K_Insight on Dyno
- License plate mount CRZ
- Honda CR-Z B18C1 Swap
- Honda Insight 2011 AUX input port
- Odd heat vent symptoms
- Hello to all
- Weird clutch issue
- Insight help after minor accident
- 2011 Insight most dash lights on.
- Budget B-Series Build
- I want one but I have questions.
- Going to buy Honda CRZ 2010 with 90k KM
- decide to buy 2015 CRZ, some questions
- DOOR CHIME LOCATION. Honda CR-Z
- K24 Insight
- Window Glass Replacement
- Happy New Insight Owner. I knew it would happen one day!
- what works as O2 sensor for 2003 Insight MT?
- 2014 CRZ AEM Cold Air Intake 21-700
- ac problem
- Anyone selling a Honda CRZ Body or Vehicle?
- Looking to buy an 'Old' new CRZ from Dealer
- CEL Won't Light With Ignition On- 00 Insight
- 2013 CRZ Stuck Parking Brake -- Help!
- 2001 Insight problems/value
- Fuse descriptions/locations
- Autism Awareness Ksight build Delacruz Motorsports
- my 2013 Insight
- Don Nguyen | Matte black vinyl roof wrap - White Honda Insiight
- 2010 Insight Spark Plugs.
- A round nordschleife with the CRZ...
- 2010 Insight Modifications
- Deleting Hybrid system from CR-Z, replace with normal L15 engine
- world record speed Insight Crash. warning bad
- Key won't turn, stuck at 0 (OFF)-2002 Honda Insight
- Location of A/C Compressor Relay
- HID headlights for 2010+ Insight?
- tires recommendations
- Honda Insight project Questions?
- Help installing aftermarket subwoofer in base 2011
- Why I decided to purchase a CRZ
- Getting more power from the 2010 Insight engine?
- CR-Z build. Slowly but surely. Couple mods.
- 2011 Insight Key stuck in ignition
- First Gen Insight Double Din Dash Kit (Need Your Help)
- OBDII
- Anyone have TSB 12-048? regarding IMA battery panel
- High Performance Fuel Injectors
- 1G Insight Spring kits
- CR-Z Autocross
- HPD CRZ at SEMA 2012
- 2000 Honda Insight question..Technicians help!!
- crz mugen kit front plate?
- is this correct
- new honda insight owner 2001
- Mugen Honda CR-Z RZ (Limited run)
- New Member Introduction
- Gauges aren't changing color
- CR-Z Gato Performance Intake Manifold
- Window Leaking
- CR-Z usb with jailbroken iphone
- Jackson Racing Releases CR-Z Supercharger Kit
- crz with advanced keys upgrade question
- 2012 Insight strange dash noise
- new member
- 2011 Honda CR-Z Maintenance and Modifications....
- 10 sec street insight
- Issues with 01 Insight MT
- Insight drag racing
- hellaflush crz!!! check it out
- window replacement?
- LSD for CRZ
- Here's Mine Premium White Pearl 2011 CR-Z EX
- Prayoonto Racing BC insight
- CR-Z Seibon Carbon Front Lip....any pics out there?
- 2012 CRZ TEST DRIVE & EXPECTATIONS
- 2012 Insight paint code YR593P Truffle Pearl Paint match issue!
- Question for all the M/T CRZ owners
- Removing tailight from 2011 Honda Insight
- Issues with the 3rd going in, 2012 CRZ???
- Can you please tell me if these speakers will fit in my Insight 2012 Base Model
- Sportcar Motion: Project Dirty Hybrid! CRZ
- 09 civic hybrid BUY or PASS
- Eibach K24 CR-Z update & track footage
- 261km/h 350hp CR-Z turbo
- got a question.. is crz worth time to get?
- crz dyno day today
- Hondata to release FlashPRO for CR-Z
- CR-Z sales figures... not good.
- Ever wonder how much the Hybrid stuff weighs?
- Oh Well.... Nothing new for the 2012 CR-Z
- Need Car fax
- crz advice
- CRZ Black Label
- New Ford Focus is CRZ?Z?Z
- Gen 1 Honda Insight Ground Control coilovers
- CRZ OFFSETS
- CRZ Door Issues
- cr-z good or bad to buy
- Honda CR-Z Mugen RR
- Insight Blinker Relay......MIA
- Car Seat in a CR-Z
- Found a neat CRZ Commercial
- Wow possible Honda CR-Z Bisimoto Edition
- Warranty question
- HELP! 2011 Insight (base model)
- First Molding aero bonnet, and cooling panel
- New member hello
- My Z
- T1R S51 Exhaust
- CR-Z euro mugen
- Newbie to the hybrid world.
- I saw my first CRZ on the road
- Mugen CR-Z - Supercharged (197hp/181tq)
- My Crz
- CRZ x DC5 ITR'S x BUDDY CLUBS x DUCKBILL
- CR-Z Photoshoot Two
- AEM Cold Air Intake
- Electric AC Compressors: true?
- Black and White CR-Z
- Feel's Honda Twincam Bonnet
- Crystal Black Pearl Noblesse CR-Z
- Ganador LED Super mirror
- Noblesse Diffuser and Exhaust installed!
- AMS Carbon Fiber Steering Wheel
- My CRZ finally came in...
- Honda R&D confirms working on high-performance CR-Z
- Mugen Euro CRZ
- Trouble storing phonenumbers by voice recognition!!!
- T1R S51 Exhaust DYNO !!!
- KR-Z on the Cover of Honda Tuning Magazine
- It's official, get ready for the Mugen Crz.
- How is the manual startup after the engine turns back on?
- My CR-Z light tuning, video.
- Litterally how long does the IMA last before its all used up?
- The CR-Z has landed..
- CR-Z - no bueno for tall people..
- Ksport full coilovers coming soon for the 1st gen insight!
- Paint Codes for CR-Z?.
- Honda to Fast track new CRZ
- Bought an Insight.. needed a reason to visit Honda-Tech again.
- Top Gear (USA) features CR-Z
- CR-Z makes Motor Trend Top Ten Worst Handling list
- perspective buyer
- hottest cr-z yet!!!!!
- Real curb weight, engineless.
- New to honda but considering cr-z
- CR-Z getting a conventional engine
- T1R S51 Exhaust installed !
- LHT Performance CR-Z K20
- Honda Planning Turbo 1.6L CR-Z - 200hp Type-R to Follow
- CRZ @ Thunderhill's 25hrs of Thunderhill 12-4-2010
- Classy CR-Z
- CR-Z's at the L.A. Auto Show
