Honda Insight & CR-Z Hybrid Honda Insight and CR-Z Hybrid discussion forum.
CRZ OFFSETS
Old 09-01-2011, 10:07 PM
Default CRZ OFFSETS
What are the average offset on the crz around here? I'm into the hellaflush scene because obviously i bought this car to save gas so i can spend it on tires . Please post up a picture and offset please!! :D
Chanhtastic is offline
Old 09-02-2011, 06:48 AM
Default Re: CRZ OFFSETS
any help? does anyone know the offset of the stocks?
Old 09-02-2011, 12:55 PM
Im running 17x9 +38 in front and 17x9.5 +38 in rear and it required rear bumper mount modification as well as camber in front to fit. Running camber bolts top and bottom.
hotboxn is offline
Old 09-02-2011, 01:16 PM
^^ clean
lawrencesor is offline
Old 09-02-2011, 01:51 PM
I like! :D
Janet@bisimoto is offline
Old 09-03-2011, 11:42 AM
front is now 1" lower and rear is 3/4" lower. Swapped out for 215/45 in front and still running 225/45 in the rear.
hotboxn is offline
Old 09-04-2011, 01:38 PM
cmyrex's Avatar
Wow that's sexy I drove one of these at work yesterday for the first time that **** gets it for a hybrid I was very surprised
cmyrex is offline
Old 09-07-2011, 03:52 PM
jisam's Avatar
i believe crz has very similar offset of 8th gen civic. ( i guess including 9th gen civic ).
jisam is offline
Old 09-12-2011, 07:08 AM
looks nice bro! i was planning on running 18x9.5 +22! i think thats going to be perfect then compare to your offset! thanks for the help!
Old 09-12-2011, 10:08 PM
Should work out with a little bumper mount work and some roll
hotboxn is offline
Old 09-13-2011, 07:30 AM
Car looks really good hotboxn.
Deatschwerks is offline
Old 09-14-2011, 07:22 AM
Thx!
hotboxn is offline
Old 09-16-2011, 09:44 AM
DAmmmmm ****en sick, like the whole white color theme =]
JDM love MAGana is offline
Old 09-16-2011, 12:06 PM
I really, really, like those wheels on the white CRZ!
Old 09-17-2011, 12:33 AM
looks sweet
efcivic91sired is offline
Old 09-27-2011, 12:13 PM
Thanks! I'm def happy w/ how they turned out! And thanks to everyone else for the compliments as well!
hotboxn is offline
Old 11-05-2011, 08:20 PM
2x0
2x0's Avatar
To answer the original question the stock wheels are +45 offset, in either a 6" wide standard or 6.5" wide optional oem wheel. The front wheels are flush at about 15-20mm lower offset than stock, and the rears at 30-35mm. If you want a flush look in back and no poke in front youll have to run spacers in the rear or a staggered setup, since the rears are much more sunk in.
Also if you lower the car on anything wider than stock wheels, you will probably need to run slightly stretched tires, negative camber and/or roll and shave the inside of the fenders. This car is not friendly for aggressive fitments, but it can be done.
2x0 is offline
Old 01-06-2012, 03:15 PM
someone should do the varrstoens 17x9 +30 !
phizstuh is offline
Old 02-15-2012, 01:12 AM
Evotechnik's Avatar
Phizstuh - No Fake Wheels Please!
Car looks good Justin... i'm going with 17x9.5 +38 with 225's all around on my setup... NT03 Hella Flush!
- Basis Sport Tony
Evotechnik is offline
Old 02-15-2012, 08:01 PM
It'll be fun pulling those fenders w/ 225's and 9.5's. It'll look good though.
hotboxn is offline
Old 02-22-2012, 01:57 PM
clean!!!
pmgoce15 is offline
Old 02-25-2012, 05:47 AM
og asr's Avatar
Would I have any problem mounting this size on the rear?
17x9 offset +44 114.3
og asr is offline
Old 03-20-2012, 02:19 PM
9" width should work for the rear, probably be a sweet look
Z-Roots is offline
Old 03-20-2012, 05:27 PM
Mattyg2's Avatar
RWD stagger on a FWD? what?
Mattyg2 is offline
Old 03-21-2012, 05:39 AM
autocity's Avatar
Here are some Advan RGII wheels.
179.5 +35 all around
215/40f
225/40r
This is on one of our riders CRZs. Check out some info and some photos of his car here...
Link: http://www.autocityimports.com/blog/2012/cr-z-bagged/
autocity is offline
Quick Reply: CRZ OFFSETS
  • Ask a Question
Question Title:
Description:
