Honda Insight & CR-Z Hybrid Honda Insight and CR-Z Hybrid discussion forum.
OBDII
Old 01-26-2013, 07:24 AM
Icon2 OBDII
DO ANY ONE KNOWS OF A GOOD AFTERMARKET CODE READERS FOR HONDA HYBRID AND BE ABLE TO READ BATTERY CELL VOLTAGE?
DINO AUTO is offline
Old 02-01-2013, 10:27 PM
Default Re: OBDII
Doesn't autozone have code readers that work on all cars? Or are hybrids an exception from that?
bairdandrew77 is offline
Old 02-03-2013, 07:33 PM
Default Re: OBDII
Obd reader will not read cell battery voltages, but does work for crz... The car itself does all readings and measurements for the hybrid battery system... There are special equipments that people use to measure the cells, but you'd want to read more about that specifically... Go to the honda insight forums to learn more!
brett304 is offline
Old 06-18-2013, 01:44 PM
Default Re: OBDII
My genesis can get get quite a bit of data out of the IMA module on my '03 civic. Not sure about cell voltage though. A genesis will set you back 2500 bucks, so If you don't own a shop its an expensive tool just to use a couple times a year. If you're having any problems the system should throw you some trouble codes to give you an idea of where to go with manual testing.
Darren Thiesen is offline
Old 07-03-2013, 07:28 PM
Coopa B18c5's Avatar
Default Re: OBDII
i used to work at honda and we would have to use a mdi with a laptop to get the information you're looking for. or you can go out and buy a 2400 dollar snap on scanner
Coopa B18c5 is offline
OmarR
02-09-2016 06:16 AM
OneSlowEkHatch
10-16-2015 06:09 AM
thaijdmpart
11-19-2014 11:37 PM
allJDMcivic
12-16-2010 04:03 PM
Newborn_
Acura NSX
06-17-2006 11:31 AM
Quick Reply: OBDII
  • Ask a Question
Question Title:
Description:
