Honda Insight & CR-Z Hybrid Honda Insight and CR-Z Hybrid discussion forum.
Gen 1 Honda Insight Ground Control coilovers
Old 09-12-2011, 10:39 AM
Blue-Civic-Hybrid's Avatar
Icon6 Gen 1 Honda Insight Ground Control coilovers
Just in case anyone out there wants to get a better suspension setup for their Gen 1 Honda Insight, your wait might soon be over. Currently in the prototype phase and under going testing on my Insight...
Blue-Civic-Hybrid is offline
Old 09-12-2011, 09:52 PM
GDD Member
slomofo's Avatar
Default Re: Gen 1 Honda Insight Ground Control coilovers
Any estimated time for release?
slomofo is offline
Old 09-13-2011, 10:07 AM
Time of release is dependent upon aftermarket dampers/shocks and overall interest. The rear shocks of the Insight will be troublesome to reproduce due to size and weird mounting.
Old 02-22-2012, 11:05 AM
Hello,
how`s things at the moment?
Is there a solution to the suspension of the ZE1?
regards
Preludegreen is offline
Old 09-06-2012, 12:26 PM
Anyone rolling around on a ground control setup yet? I know i'm somewhat reviving a dead thread but i'm interested in seeing what options may soon be available for us gen1 owners.
BARB3R is offline
Old 09-13-2012, 07:44 AM
I've had the GC's on my insight since i posted the prototype pics and i have replaced the rear shock with some from Monroe.
As for ride comfort, they are definitely much stiffer than stock but improve handling greatly in my opinion. No more "floaty" suspension feel at speed and door handle scraping cornering.
These are available on GC's website for all Gen 1 Insights.
If you want more info for Gen 1's in general, check out www.insightcentral.net
Old 12-06-2012, 12:21 PM
dkim48's Avatar
Is it true people use caddy shocks as a replacement for the rears?
dkim48 is offline
Old 12-08-2012, 07:26 AM
do you have finished pictures on the car?
tkocrx is offline
Old 12-11-2012, 10:19 AM
No, the Monroe shocks I used are from a 1995 Chevy Cavalier.
Old 12-11-2012, 10:22 AM
I will post some pics up later this week, I never took any of them lowered.
Old 12-11-2012, 11:30 AM
Here she is lowered on my old Mugen RNR's. I only lowered here half an inch.
Old 01-02-2013, 04:52 AM
CRXBart's Avatar
Location: Land of the free, whoever told you that is your enemy
good info. Thanks for sharing.
CRXBart is offline
Old 01-04-2013, 10:17 AM
TunerN00b's Avatar
The Cadillac Cimarron was the same chassis as the Cavalier, and used the same rear shocks.
TunerN00b is offline
Old 01-25-2013, 11:06 PM
Put the new pics up!
Old 05-03-2013, 03:53 PM
wutthebun's Avatar
are these on the market now?
wutthebun is offline
Old 05-04-2013, 05:54 AM
Yes they are on the Ground Control website...
Old 05-30-2013, 11:38 AM
Ground control makes awesome coilovers. We've used them on our past track cars and they handled amazing!
WheelStudio is offline
Old 07-26-2013, 12:43 PM
How many company's make coilover kits for the Insight besides GC and Tanabe? Seems like an older chassis but doesn't it work with the CR-Z as well?
hondapal is offline
Old 09-14-2013, 01:57 AM
vtecn8ive's Avatar
I'm curious when you go lower with the Insight what type of camber kit do you use?
vtecn8ive is offline
Old 09-14-2013, 07:12 PM
Rear doesn't matter but the fronts you can use an SPC camber kit, bought mine at Summit.
Old 09-16-2013, 06:21 PM
TunerN00b's Avatar
It's a twist beam suspension. You shim it in the rear to change camber and/or toe.
http://www.andysautosport.com/honda/...shims/ingalls/
Old 09-18-2013, 05:23 PM
Icon6 Re: Gen 1 Honda Insight Ground Control coilovers
TunerNoob, thanks for the info, I didn't know about those shims for the rears. I don't think I will use them since my alignment seems to be none the worse.
Here is my Insight lowered on GC's and custom rear shocks from GAZ shocks in the UK.
Old 09-19-2013, 09:58 AM
TunerN00b's Avatar
I hope you got it aligned anyway. If the car had any negative camber stock in the rear, it will now have additional toe in due to the change in angle of the twist beam.
Also, now that you have a more performance oriented ride height and (assuming) spring rates, you probably want a more performance oriented alignment. Shim the rear to 0 toe instead of the factory specified toe in and the car will feel much more responsive.
Old 09-21-2013, 09:54 PM
Perfect! Yes, the spring rates are about 20 to 25% stiffer. As for the rear toe, it was checked and it was at 0 degrees during my alignment.
Old 09-23-2013, 08:53 PM
vtecn8ive's Avatar
Do you have more info on the GAZ struts?
Quick Reply: Gen 1 Honda Insight Ground Control coilovers
  • Ask a Question
Question Title:
Description:
