ac problem
ac problem
I have been working on my 2006 Honda crv and i had replaced the ac compressor, but now that i replaced it it is not engaging once it is turned on. Yes i put freon in it i keep reading, and it says to go to the relays, but i dont know how to check these relays. i need to know where the ac compressor relay is located as i read it says it is on the fire wall or the wheel well but the only thing i am finding in the wheel well is a thing for the airbags. i suppose a airbag sensor. please help me and please give specific directions. thank you.
Re: ac problem
The A/C compressor clutch relay for 2006 CR-V is located in the under-hood fuse relay box.
The A/c compressor clutch is relay #2 in the diagram. The relays in slots # 1, 5, 6, 9, and 10 should be the same type as the A/C compressor clutch relay. You could try swapping relay #5, 6, or 10 with it, to see if it makes a difference.
But, your problem may not be due to a faulty relay.
Re: ac problem
I have a 2000 Honda accord and I need to replace the receiver pipe, the pipe that comes from the firewall to the receiver near the radiator at the front, needless to know I don't know where to start. There's a hole in the pipe close to the receiver I ordered the pipe and it seems like a easy fix? I'm going to try to replace it seeing if anyone on here can give me some tips????
akb427
Honda Civic (2001 - 2005)
06-28-2013 08:51 AM
