CR-Z Gato Performance Intake Manifold
Here is a look at the Gato Performance Intake Manifold we had fabricated for one of our customers. I wanted to share this with all the CR-Z enthusiast because we had notice the lack of performance parts for this car.
Re: CR-Z Gato Performance Intake Manifold
I assume this is for a turbo setup?
Not much in the way of parts available. Bisi has some head parts, Action has a clutch, Quaife has an LSD, MFactory has an LSD and final drives, and thats about it.
Skunk 2 makes no crz parts. Do you mean the spoon that's what I have it's the only one besides j's racing
The lsd's are supposed to be interchangeable with The k series there the same part numbers for a few companies so whatever is available for the k series as far as LSD you can use and where is this clutch the only one I've ever seen is the hks and the bisimoto spec one
Here a semi turbo manifold as I called it for CR-Z. The reason why is done this way is so the customer can actually bring the turbo to the side in like some sort of sidewinder type of manifold. All you have to is weld a the rest of the ss tube and position the turbo any where you like.
Here is link where you can see the engine built.Ne Sleeves,Valves and a lot of other stuff done to the LEA1 Engine.
https://www.facebook.com/media/set/?...1¬if_t=like
DJLikwid
05-08-2007 03:41 PM
