Help me understand turbo talk...
Okay, so im trying to learn about FI and ive been reading threads here and there trying to pick up what i can about turbos. Ive read all the threads and websites that teach turbo basics but I still dont understand a lot of this turbo talk...
i was looking at a thread where people posted their set up and i was just wonder what they meant by some stuff..
(sorry, i stole this from someones post)
-the things in bold, what are they and what does it mean?
d16y7
cp pistons
eagle rods
arp's
ferrea valves/springs/retainers
rc 550's
...etc....etc...
t3/to4e 50 trim .48 ar
spec stage 3 6 puck clutch
ACT streetlite flywheel
hondata s100b
D16Z6 (bone stock, engine wise) w/78000 miles
Hondata s200
RC 550's
BBK 255lph fuel pump (in-tank)
....etc...etc...
Imperial 12" slim line fans (custom brackets by Ladysman, good stuff )
Defi-link Boost & EGT gauges (and Defi-link controller II)
PLX 350 wideband
thanks...
d16y7
cp pistons
eagle rods
arp's
rc 550's
...etc....etc...
hondata s100b
Hondata s200
RC 550's
....etc...etc...
PLX 350 wideband
thanks...
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by variablevalve »</TD></TR><TR><TD CLASS="quote">Okay, so im trying to learn about FI and ive been reading threads here and there trying to pick up what i can about turbos. Ive read all the threads and websites that teach turbo basics but I still dont understand a lot of this turbo talk...
d16y7
cp pistons
eagle rods
arp's
rc 550's
...etc....etc...
hondata s100b
Hondata s200
RC 550's
....etc...etc...
PLX 350 wideband
thanks...</TD></TR></TABLE>
ARP = ARP headstuds. Replacements for the stock headbolts that hold the head, HG and block together. Stronger than stock and cheaper!
RC 550's = 550cc fuel injectors, as opposed to stock D/B-series 240cc injectors.
Defi-Link Boost and EGT gauges = gauges for your turbo setup (duh). Boost displays how much boost your turbo is creating, and the EGT gauge stands for Exhaust Gas Temp., which reads from a probe installed in your turbo manifold and tells you how hot your exhaust gases are getting, a good indicator of how rich/lean you're running as well.
PLX Wideband = a unit that determines your exact air/fuel ratio, whether it be under boost (when your turbo is spooling and as a result you go fast
) or in Vacuum (turbo's not creating any boost, i.e. driving at low RPM / low throttle usage).
My explanation sucks, others will chime in.
d16y7
cp pistons
eagle rods
arp's
rc 550's
...etc....etc...
hondata s100b
Hondata s200
RC 550's
....etc...etc...
PLX 350 wideband
) or in Vacuum (turbo's not creating any boost, i.e. driving at low RPM / low throttle usage). My explanation sucks, others will chime in.
https://honda-tech.com/zerothread?id=153810
Hope it helps
Hope it helps
hey newbie..
read through every single link
posted by MikeMan
Help List
https://honda-tech.com/zerothread?id=67146 -oil return
https://honda-tech.com/zerothread?id=109160 -oil return line setup
https://honda-tech.com/zerothread?id=114490 -oil return line parts
https://honda-tech.com/zerothread?id=71999 -where to weld oil return
https://honda-tech.com/zerothread?id=119100 -oil return line
https://honda-tech.com/zerothread?id=119539 -oil pan welding
https://honda-tech.com/zerothread?id=119715 -oil pan welding
https://honda-tech.com/zerothread?id=118687 -oil grade to use
https://honda-tech.com/zerothread?id=118694 -ft for oil feed line
https://honda-tech.com/zerothread?id=118807 -oil feed line
https://honda-tech.com/zerothread?id=119681 -oil feed line
https://honda-tech.com/zerothread?id=93550 -part for oil feed line
https://honda-tech.com/zerothread?id=114436 -where to buy brass t for feed line
https://honda-tech.com/zerothread?id=126335 -oil t question
https://honda-tech.com/zerothread?id=125438 -another place to buy oil lines
https://honda-tech.com/zerothread?id=131447 -oil feed line an/npt connector ?
https://honda-tech.com/zerothread?id=134078 -feed diagram
https://honda-tech.com/zerothread?id=133948 -oil bpst fitting again
https://honda-tech.com/zerothread?id=144586 -oil feed line restrictor
https://honda-tech.com/zerothread?id=155510 -oil leaks
https://honda-tech.com/zerothread?id=158018 -oil feed 3' better
https://honda-tech.com/zerothread?id=156571 -oil pan bolts
https://honda-tech.com/zerothread?id=170223 -oil pressure readings
https://honda-tech.com/zerothread?id=168084 -oil feed fitting
https://honda-tech.com/zerothread?id=131450 -oil feed diagram
https://honda-tech.com/zerothread?id=195068 -oil pressure
https://honda-tech.com/zerothread?id=122635 -drag 3 (to) coolant line?
https://honda-tech.com/zerothread?id=116891 -closed loop turbo info
https://honda-tech.com/zerothread?id=119724 -drag 3 turbo fitment (filing block)
https://honda-tech.com/zerothread?id=119690 -vacuum source
https://honda-tech.com/zerothread?id=94820 -closed loop
https://honda-tech.com/zerothread?id=120814 -Drag3 downpipe
https://honda-tech.com/zerothread?id=120867 -Drag3 + Tial connection
https://honda-tech.com/zerothread?id=118699 -wastegate vacuum line
https://honda-tech.com/zerothread?id=118767 -feul pump for drag 3
https://honda-tech.com/zerothread?id=121442 -fittings (brass T on block)
https://honda-tech.com/zerothread?id=123326 -blow off valve tightening
https://honda-tech.com/zerothread?id=123925 -catalytic converter removal o2 sensor
https://honda-tech.com/zerothread?id=124474 -'burning' in the turbo + blow off valve ?
https://honda-tech.com/zerothread?id=124580 -drag 3 manifold boost spike issues
https://honda-tech.com/zerothread?id=124662 -drag 3 tial fitment
https://honda-tech.com/zerothread?id=151845 -closed loop dump tube
https://honda-tech.com/zerothread?id=155616 -flexpipe issue
https://honda-tech.com/zerothread?id=159889 -blow off valve adjusting/cleaning
https://honda-tech.com/zerothread?id=163453 -egt probe tapping
https://honda-tech.com/zerothread?id=167329 -o2 sensor bung
https://honda-tech.com/zerothread?id=170498 -don't use tial gasket
https://honda-tech.com/zerothread?id=175270 -intercooler direction
https://honda-tech.com/zerothread?id=175277 -drag bolts suck
https://honda-tech.com/zerothread?id=206376 -bov greddy type s (loose)
https://honda-tech.com/zerothread?id=120548 -hondata install (solder stuff)
https://honda-tech.com/zerothread?id=98092 -hondata install heiarchy
https://honda-tech.com/zerothread?id=121859 -hondata info on pumps
https://honda-tech.com/zerothread?id=117300 -spark plugs
https://honda-tech.com/zerothread?id=156273 -spark plugs (2)
https://honda-tech.com/zerothread?id=116886 -changing plugs
https://honda-tech.com/zerothread?id=117326 -flexpipe for good price
https://honda-tech.com/zerothread?id=117733 -injectors, 440 or 550
https://honda-tech.com/zerothread?id=119569 -guage for autometer
https://honda-tech.com/zerothread?id=119591 -autometer guages
https://honda-tech.com/zerothread?id=121452 -aero fpr
https://honda-tech.com/zerothread?id=119884 -best FPR?
https://honda-tech.com/zerothread?id=118885 -place to buy aem fpr
https://honda-tech.com/zerothread?id=122590 -(installing) aeromotive fuel regulator
https://honda-tech.com/zerothread?id=86051 -removing/installing intank fuel pump
https://honda-tech.com/zerothread?id=120889 -profec b install
https://honda-tech.com/zerothread?id=116651 -Radiator fans
https://honda-tech.com/zerothread?id=119819 -diff between mechanical/electrical gauges
https://honda-tech.com/zerothread?id=117513 -turbo XS boost controllers and tial wastegates
https://honda-tech.com/zerothread?id=122396 -block guard
https://honda-tech.com/zerothread?id=107030 -rc 440 injector polarity
https://honda-tech.com/zerothread?id=82211 -rc 440 after hondata install
https://honda-tech.com/zerothread?id=121452 -aeromotive fpr part #
https://honda-tech.com/zerothread?id=125639 -hks ssbv clip
https://honda-tech.com/zerothread?id=153531 -more hks bov install
https://honda-tech.com/zerothread?id=125852 -carsound cat part #
https://honda-tech.com/zerothread?id=92570 -turbo timer relay
https://honda-tech.com/zerothread?id=128321 -turbo timer wiring
https://honda-tech.com/zerothread?id=132485 -radius rods
https://honda-tech.com/zerothread?id=63095 -rear seat removal
https://honda-tech.com/zerothread?id=133644 -injector fitment
https://honda-tech.com/zerothread?id=104940 -thermal to cat issues
https://honda-tech.com/zerothread?id=136680 -egt guage stuff
https://honda-tech.com/zerothread?id=137223 -which runner to tap for egt
https://honda-tech.com/zerothread?id=55987 -aem fpr against strut bar
https://honda-tech.com/zerothread?id=139706 -tools to carry
https://honda-tech.com/zerothread?id=140003 -base fuel map
https://honda-tech.com/zerothread?id=140774 -bleeding coolant
https://honda-tech.com/zerothread?id=156073 -js safeguard
https://honda-tech.com/zerothread?id=168470 -js safeguard, who is using
https://honda-tech.com/zerothread?id=160428 -summit part
https://honda-tech.com/zerothread?id=170160 -9psi, raise static fuel + retard timing
https://honda-tech.com/zerothread?id=170821 -wires to tap for guages
https://honda-tech.com/zerothread?id=171397 -c clamp pliers for hks bov
https://honda-tech.com/zerothread?id=171314 -EGT temps
https://honda-tech.com/zerothread?id=166449 -vacuum sources
https://honda-tech.com/zerothread?id=175335 -assembling an fittings
https://honda-tech.com/zerothread?id=176725 -oem fan clearance - move to right
https://honda-tech.com/zerothread?id=193263 -greddy profec b
https://honda-tech.com/zerothread?id=85987 -installing rc injectors
https://honda-tech.com/zerothread?id=106033 -matching wires rc injectors
https://honda-tech.com/zerothread?id=133644 -fitment of rc injectors
https://honda-tech.com/zerothread?id=107030 -polarity does not matter
https://honda-tech.com/zerothread?id=154935 -once installed
https://honda-tech.com/zerothread?id=159623 -tips to install
posted by MikeMan
Help List
Vtak
Jan 30, 2005 01:49 PM
