steel intake manifold, sheet..... anybody made one?
something different
like the topic says, has anybody ever made a steel sheetmetal intake for a honda? i searched , but got nothing.....just curious. i'm in process of fabbing mine.
-cheap
-easy to work with
-cheap
-already had steel velocity stacks that will work perfect as runners
-cheap
-cheap
-easy to work with
-cheap
-cheap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fork »</TD></TR><TR><TD CLASS="quote">you can't make something cool like that and not post pics
If you worried about heat you can get it ceramic coated, that will help</TD></TR></TABLE>
ot really, the engine is going to radiate heat on it and its going to act as a heak sink. ceramic coating will help is absorb heat from around it, but not from within.
something different
theoretically, aluminum absorbs heat faster than steel...(if it is the same thickness, etc.)
using a phonelic gasket, it should be decent.......
i'm debating ceramic coating it....not sure. we'll see.
oh, and yeah, my brother and i have a tig david.......and we could do aluminum....but it really is more of a pain, and costly. total budget for this manifold-85 bucks.
guess nobody has really done this....oh well. cool.
aluminum changes temperature faster, heat is a constant.
but overall i think the differences will be nil. The aluminum will heat up faster, and it will transfer heat to the air (internal and external) faster.
Plus after any sgnificant run time with the hood closed the manifolds will both be the same temperatures.
something different
awesome find david.
very good info too. mine will be fashioned after the supra intake manifolds that MVP motorsports makes. i'll see if i can find a picture of one...
will have a HUGE plenum, with velocity stacks as the runners. REALLY short runners.
So when are you gonna build a sweet exh manifold for that sucker? I have like 12 mild steel weld els you can have for like free. I like stainless
edit: here is where that link came from. Crap loads of sweet tech articles.
http://www.sdsefi.com/tech.html
something different
yeah, but he doesnt make them for a sohc right now, doesnt want to make a single one........understandable.
i'm sending a gasket to exploited soon, whenever i get around to it. he said he'd do it for 65 bucks.
There are only two reasons aluminum is used to make intake manifolds. One, it is about as lightweight as you can go cheaply. Two, and more importantly, aluminum is easier to cast and machine. If manufacturers had to weld manifolds together, bets are good that most would choose steel as a material.
On the other hand, most of the 60's and 70's cars I have owned had iron intake manifolds, until I swapped them out for aluminum.
redzcstandardhatch
Welding / Fabrication
Sep 9, 2005 03:34 PM
