welding safety
Old Dec 4, 2005 | 10:22 AM
cua0's Avatar
Default welding safety
figured i would make sort of an informative or semi-informative post regarding Personal Protective Equipment (PPE). since industry Occupational Health and Safety here mandates very strict control of workers protective equipment I figured I would share what is required of me as a welder in industry.
Coveralls: need to be fire retardant (obviously)
I Prefer carhartts bib overall in black.
Shirt: Long sleeves are a must, I prefer long sleeve shirts with collars,"cowboy shirts" or old dress shirts that are 100% cotton.
I like to go to value village (thrift store that sells used clothing) and pick up 8 shirts for $5.00
something like this is what i aim for.
I prefer the "cape sleeve" leather jackets, they're not too hot and they provide adequate protection from burns.
Gloves: I'm very picky about the kind of gloves i wear, I usually get the "cold weather" tig gauntlets, but I can never find pictures of them online, they look like regular tig gauntlets only they're a bit thicker and have a wider cuff.
like that, only different. heh.
Safety Glasses: it's been beat into me over the last 6 years to always wear safety glasses, even under my helmet, so it's just habit now and i feel naked if i'm not wearing them heh.
the ones i currently prefer are at the bottom of this image, the clear lense ones.
Welding Helmet: I have 4 helmets, each has a different purpose. I have 2 pipeline helmets, one auto-darkening and one standard beater.
i have a standard narrow footprint flip front helmet for mig/stick work and non-precision work made by AirLiquide.
my precision work helmet is an AP tools solar auto-darkening helmet which i just got. very nice unit.
I also put sunscreen on my face and neck, spf40 or better, because i do a lot of tacking with my helmet off and my eyes closed.
I think that about sums it up.
questions & comments welcome
Old Dec 4, 2005 | 10:25 AM
RCautoworks's Avatar
Default Re: welding safety (cua0)
Only comment I have is about the shirts . I have been using work shirts like that, and when mig welding, the shirts don't really protect you. I would recommend a welding jacket.
Old Dec 4, 2005 | 12:38 PM
cua0's Avatar
yeah, thats why i said i buy a dozen at a time from the local thrift store. you will burn through them if you're using an argon-co2 mix, if you use straight argon you won't have as much spatter and won't get as many burns (heroin addict looking burns on your arms)
like i said i also recommend cotton sleeves or a leather jacket. you can get the cotton sleeves anywhere you can get the leather jackets usually.
Old Dec 4, 2005 | 02:16 PM
Default Re: (cua0)
But its hard to weld when spatter is burning your arms.
Old Dec 4, 2005 | 02:42 PM
Bailhatch's Avatar
Default Re: (90blackcrx)
I don't look nearly as cool, but i do have a jacket similar to this dudes
Old Dec 4, 2005 | 02:58 PM
Lamchop0000's Avatar
Default Re: (Bailhatch)
im rockin the tillman lightgreen coat. 20 bucks at praxair
ignore the homo
Old Dec 4, 2005 | 03:02 PM
cua0's Avatar
the sleeves i was talking about, the cotton ones are just like the green coat that lamracing posted.
they're cheap as hell, disposable, but they work pretty good.
Old Dec 4, 2005 | 03:06 PM
Default Re: (LamRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LamRacing &raquo;</TD></TR><TR><TD CLASS="quote">im rockin the tillman lightgreen coat. 20 bucks at praxair
ignore the homo</TD></TR></TABLE>
I need to pick one up.
Old Dec 4, 2005 | 03:44 PM
c jackson's Avatar
threes
Default Re: (cua0)
how about fumes?
Old Dec 4, 2005 | 03:46 PM
Electron_LS-Vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">I need to pick one up.</TD></TR></TABLE>
The shirt.... or the HOMO?
Old Dec 4, 2005 | 04:38 PM
Default Re: (Electron_LS-Vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Electron_LS-Vtec &raquo;</TD></TR><TR><TD CLASS="quote">
How did I know someone would say that.
The shirt
Old Dec 4, 2005 | 04:42 PM
cua0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c jackson &raquo;</TD></TR><TR><TD CLASS="quote">how about fumes?</TD></TR></TABLE>
i only ever worry about the fumes in confined spaces like vessel work and then i have a respirator with a remote filter kit on it that hangs about 2/3's down my back so that i get air from as far away from the plume as possible, or if it's a really confined space and i'm going to be a long time i get supplied air.
or an SCBA similar to this, but with a welding helmet instead of a clear helmet.
Old Dec 4, 2005 | 06:00 PM
.RTErnie's Avatar
Default Re: (cua0)
ventilation...especially with aluminum. For some reason aluminum chokes me up the worst.
Old Dec 5, 2005 | 12:20 AM
also that tillman light green coat has a pocket, on the inside leftside.
just letting ya'll know. its good for holding belongings.
Old Dec 5, 2005 | 01:51 AM
k24em2's Avatar
I've got a long leather apron thats handy for saving your pants.
Old Dec 5, 2005 | 07:52 PM
c jackson's Avatar
threes
Default Re: (~RTErnie~)
cause aluminum is pretty bad...alzheimers (sp) bad.
Old Dec 7, 2005 | 01:10 AM
cua0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ~RTErnie~ &raquo;</TD></TR><TR><TD CLASS="quote">ventilation...especially with aluminum. For some reason aluminum chokes me up the worst.</TD></TR></TABLE>
you haven't done much/any galvanized welding then i take it? that **** is the absolute worst to weld as far as clean/new material goes.
Old Dec 7, 2005 | 02:21 AM
k24em2's Avatar
Default Re: (cua0)
Be careful with galvanized. You have to remove the zinc plating before you weld it otherwise bad things can happen:
Symptoms:flu-like illness with a metallic taste in the mouth, throat irritation, and dry cough;
Signs: leucocytosis (high white blood cell count) is common; normal chest x-ray;
Onset after exposure: 3-10 hours;
Heavy exposure to: zinc oxide fume or dust, e.g., after welding or flame cutting of galvanized steel, high temperature zinc coating processes, or metal pouring in brass foundries; (Brass is an alloy of copper and zinc.)
Resolution: spontaneously within 48 hours;
Comments: After an episode, there is a temporary period of tolerance for a day or two afterwards. Copper and magnesium fume can also cause metal fume fever. It is important to distinguish metal fume fever from cadmium pneumonitis.
Old Dec 7, 2005 | 12:47 PM
cua0's Avatar
yeah, i refuse to weld/cut/braze/grind galvanized, just not worth the health risks.
Old Dec 10, 2005 | 01:29 AM
MidShipCivic's Avatar
How about some online sites for people who want to mailorder
Old Dec 10, 2005 | 11:31 AM
LSiTurbo's Avatar
Default Re: (MidShipCivic)
I use this guy...
http://cgi.ebay.com/Tillman-62...wItem
Its dark so i can get it dirty and not worry about it like the seafoam colored jackets.
Its thin enough to breath and wear when im up in a car welding a cage.
And cheap.. i think i paid less then that at my local welding supply place.
inside pocket too!
Old Dec 10, 2005 | 12:29 PM
Default Re: (LSiTurbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSiTurbo &raquo;</TD></TR><TR><TD CLASS="quote">I use this guy...
inside pocket too! </TD></TR></TABLE>
This one looks more pimp !
http://cgi.ebay.com/ws/eBayISA...sting
yangmoua1988
Sep 24, 2012 05:24 PM
tim_adams85
Oct 31, 2005 08:12 PM
MSchu
Honda Motorcycles
Sep 1, 2005 11:23 AM
