thinning primer?
Old Dec 26, 2005 | 05:52 PM
silentdaredevil2's Avatar
Default thinning primer?
im soon going to want to lay some primer with a spray gun im getting from TSC and i know u have to thin out paint so it doesnt dry up in the gun but do u have to do the same with primer?
Old Dec 26, 2005 | 06:12 PM
getnasty's Avatar
Default Re: thinning primer? (silentdaredevil2)
yes I usally do it 50/50.. but it depends on what brand of paint you are using.. I use ppg... if using the cheaper stuff that is already cut pretty bad I use very little.. but you must have a eye for it
Old Dec 27, 2005 | 11:30 AM
what would happen if u thin it to much
Old Dec 27, 2005 | 02:16 PM
getnasty's Avatar
Default Re: (silentdaredevil2)
you just have to put extra coats on... you can never thin to much because you can always add more primer
Old Dec 27, 2005 | 02:30 PM
blackwagon's Avatar
Default Re: (Kaotic Kustoms)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentdaredevil2 &raquo;</TD></TR><TR><TD CLASS="quote">im soon going to want to lay some primer with a spray gun im getting from TSC and i know u have to thin out paint so it doesnt dry up in the gun but do u have to do the same with primer?</TD></TR></TABLE>
You reduce it so it will spray correctly, have your ever tried to spray paint straight out of the can? It doesn't work, it has nothing to do with drying in the gun, paint will dry in your gun with reducer in it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kaotic Kustoms &raquo;</TD></TR><TR><TD CLASS="quote">you just have to put extra coats on... you can never thin to much because you can always add more primer </TD></TR></TABLE>
You can reduce it to much because it will flash(dry) in your gun and you'll be fucked by the time you get enough on your panel.
Mixing parts is on the can, if your not sure about how much of what you should put into what call your paint rep and they will usually help you out.
Old Dec 27, 2005 | 03:04 PM
getnasty's Avatar
Default Re: (blackwagon)
never had a problem with it drying in my gun... but I always mix the way ppg says too <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackwagon &raquo;</TD></TR><TR><TD CLASS="quote">
Mixing parts is on the can, if your not sure about how much of what you should put into what call your paint rep and they will usually help you out. </TD></TR></TABLE>
are you a painter also? if so cool
ek4shizzle
Paint and Body
Dec 7, 2007 01:06 PM
turbotime
17
Mar 29, 2007 07:50 PM
deadlock32
Welding / Fabrication
Jun 26, 2005 07:53 AM
972drcordex
May 25, 2004 08:45 PM
xcom
Feb 29, 2004 03:08 PM
