MAP/TPS plug mix up, on OEM RSX-S harness w/pics.
Came with my k-swap, originally planned to use the k-tuned tucked harness which has labels, ended up sticking with this. I'm lost on which is the TPS or the other the map, I've included pics.
1st pic is a blue plug lower on the harness and just by it's self, I think this is the TPS?
2nd is what I think is the MAP, it has a 2nd plug almost directly attached to it, which isn't used with my ktuned intake manifold/tb.
Re: MAP/TPS plug mix up, on OEM RSX-S harness w/pics.
Yes, the MAP sensor and purge solenoid sit next to each other on the top of the stock throttle body.
