2005 EP3 Door Lock Issue
Old 12-09-2015, 01:15 PM
djkraiz's Avatar
Default 2005 EP3 Door Lock Issue
Just bought a 2005 Civic Si.....the doors dont lock/unlock using the door switch, nor do they lock/unlock using the keyfob.....if i close both front doors and rear hatch and lock them using the key then i can activate the factory alarm using the keyfob and can also deactivate factory alarm using keyfob, but it will not lock/unlock the doors......when you try to lock/unlock the doors using the keyfob or the door switch, you can hear the door actuators act like they are working and can also hear the relay under the dash click.......anyone have any suggestions or run into similar problems? thanks
Old 12-10-2015, 05:29 PM
djkraiz's Avatar
Default Re: 2005 EP3 Door Lock Issue
no one?
Old 12-14-2015, 12:41 PM
DC5/EP3 MOD :)
Type-Spaz's Avatar
sounds like the actuator has gone bad.
Or you need to reset your remote.
Old 12-15-2015, 05:28 AM
tommycrx's Avatar
It's most likely the actuators, if I were a betting man. I had to replace one of mine immediately when I bought it in May. Good luck - they're a royal PITA to get to.
Old 12-15-2015, 05:49 PM
djkraiz's Avatar
thanks, yea I've already reprogrammed the remote, and im surprised that all 3 actuators would go bad.........
Old 01-01-2016, 09:08 PM
Sriracha's Avatar
condor22
01-23-2019 09:16 AM
94trouble
Audio / Security / Video
20
10-04-2011 04:55 AM
Matt93eg
19
02-26-2010 06:43 PM
PatrickGSR94
02-06-2009 08:51 AM
percyv143
05-15-2006 03:29 AM
Quick Reply: 2005 EP3 Door Lock Issue
