Honda CR-V & Element 2WD & 4WD Element & CR-V
Starter problem
Old Mar 14, 2012 | 07:48 PM
Mhollaek9's Avatar
Default Starter problem
So, I've been driving my car for the last month with ZERO problems. Today I go to turn the car on and it doesnt start. I pop the hood open and i see the starter bolt all the way out. Tried to bolt it back in and nothing. Seems like the threads somehow got messed up and the top of it is somewhat stripped.....
How does one fix this? Is there something I can put in to rethread the block? Purchase a new starter bolt?
Thanks HT
(This is for a k24 btw)
________________
Old Mar 14, 2012 | 09:15 PM
tqj9's Avatar
Default Re: Starter problem
Old Mar 14, 2012 | 09:20 PM
Dc4LsTeG's Avatar
EK9
Which bolt was it? The one that holds the starter together? Or the one that bolts the starter to the tranny?
Old Mar 15, 2012 | 07:03 PM
Mhollaek9's Avatar
bolts the starter to the tranny...
Old Mar 17, 2012 | 08:01 AM
el crapitan's Avatar
helicoil. or drill and tap new threads for a bolt the next size up. it'll be easier to have the starter out to make the repair.
while the starter is out, bench test it. have a look at the ring gear. the teeth may have been damaged if the starter was cocked.
Old Apr 27, 2024 | 06:46 PM
skymaster1991's Avatar
was the the bolt that strip or the hole for the bolt?
crxaddikt
Jun 12, 2012 10:48 PM
slacks
10
Aug 27, 2007 02:23 PM
hoehouseworker
May 15, 2005 06:57 PM
Elite Hatch
Nov 24, 2002 10:06 PM
