identify if i have a high or low comp b20b
I just picked up a 99 b20b with a knock sensor and has a p75 head I'm pretty sure its a high comp but just want to double check because im confused from what other ht threads state...
Crazy Honda Guy
Re: help me identify if i have a high or low comp b20b
This is true!
Also, most of the high high comp b20 engine have the low rise intake manifold
Here is a shot of my jdm 2000 B20B (known as B20Z in north america), notice the manifold...
I believe the high comp b20b's and b20z's are the same. It's the P8R that you want.
Crazy Honda Guy
A wicked setup would be to have the newer 99+ jdm B20 or usdm B20Z, head swapped with the older P8R design. I was going to do this myself with my old setup, i even has an LS Jackson Racing supercharger for it, but sold off my hatch as the quarter panels were beginning to rust, so i never finished it
Re: identify if i have a high or low comp b20b
But isnt the P8R head have a combustion chamber of 84mm and other B20's and B18's 81mm? how do you get that to work unless you resleeve and bore?
how can i find out if my 91 civic hatch si with b20b is the b20b or the b20z? because mine has a diff intake. i dnt want to do a compression test if i dnt have to any help?
804tuned
Engine Management and Tuning
06-18-2009 10:57 AM
961, accord, b20, b20b, buy, compreasion, compression, compressoon, high, hogh, honda, identify, intake, low, sacramento, tech
