Lighting HID/Xenon kits, Retrofits and Associated Topics
HID interferes with radio reception?
Old Jan 16, 2009 | 04:49 PM
Jdmvillageidiot's Avatar
Icon3 HID interferes with radio reception?
Has anyone encountered their HID's interferring with their radio reception? If so, is there any way to combat this? Anyone? Anyone?
Old Jan 16, 2009 | 04:52 PM
B16AGUY's Avatar
Default Re: HID interferes with radio reception?
Do your interior lights dim when you tund on the HID's?
Or is it just the radio reception that's affected?
Old Jan 16, 2009 | 04:57 PM
No issues with interior lights. Reception is good until I drive further out from radio station's home city and I start to lose it and when it's time to turn off headlights the reception is back as if I just turned on an fm booster. Maybe I can move the ballast elsewhere or shield it somehow.
Old Jan 16, 2009 | 07:12 PM
omalika's Avatar
theres usually those magnetic things that goes around the wiring for the HID, i can't really remember where, but if you don't have them, that's probably the problem. if you want, i can take pictures and stuff.
Old Jan 16, 2009 | 07:37 PM
VTECROAR96typeR's Avatar
i had the same problem,so why does thing happen with the radio???..i work a 12 hr shifft so i would try to get home before it got dark so i wouldnt have to turn on the head lights
Old Jan 16, 2009 | 08:04 PM
A picture of the magnetic things would be very helpful.
Old Jan 16, 2009 | 08:23 PM
omalika's Avatar
okay, hold on, give me like 20 minutes. it's late and i'm cold and i'm on the 4th floor... hold on. and please don't laugh at my ghetto HID rig....
Old Jan 16, 2009 | 09:58 PM
omalika's Avatar
so after researching for about an hour, i'm still pretty clueless as to why a magnet helps when it surrounds a power cord. i think it's because when electricity passes through a wire, it creates a magnetic field, and the magnet surrounding it somehow dampens it... or something. someone help me on this. otherwise, you can read
http://en.wikipedia.org/wiki/Electro...c_interference
Old Jan 17, 2009 | 06:59 AM
-Bionic-'s Avatar
Former Sponsor
How are the ballasts hooked up? Using stock connectors, or using an independent wire harness with relay?
There are also noice filters, some audio expert may be able to describe it further.
Old Jan 17, 2009 | 06:02 PM
Stock connectors. It's a plug and play system. It's odd though how the HIDs only interferes when my reception is weak as when I'm in my hometown as compared to when I'm at work (closer to radion station). Btw Omalika, where would I find one of those magnetic sleeves for the wires?
Old Jan 18, 2009 | 12:35 AM
omalika's Avatar
it's just a circular magnet around the power cable leading to the HIDs. look on the AC adapters around your house, most or all of them that convert AC to DC will have one... i.e. laptops, stereos, game systems.
Old Jan 18, 2009 | 09:14 AM
erikiksaz1's Avatar
What you're looking for is a ferrite core, but i don't know how it would make up for the unshielded ballast.
The only ballasts that'll interfere with your radio reception are the shitty, unshielded ones from cheap hid kits.
This is one of the reasons why HID "kits" are not recommended. OEM hid projector/ballast setups sell all week long for less than $150 on ebay, so I don't see why people still opt to pay $80-100 for radio reception-interfering ballasts, chrome-melting bulbs, and sub-par lighting performance.
Old Jan 20, 2009 | 02:29 PM
JSPECSIR's Avatar
its common for radios to pick up interference from spark plug wires as well. the common remedy to this it to run a ground strap to your hood.(this is common on alot of american cars from the factory) you may want to try this to see if it helps.
also try using a relay harness that pulls power for the ballasts straight from the battery and give them there own ground. if there putting any kind of noise into the dc system, going to the battery for power may help filter alot of this out as well.
hope this helps.
Old Jan 22, 2009 | 04:30 PM
98civdx's Avatar
Master Detailer
mine just did it today!!
i couldnt belive it
but when i pulled my atenna out it went away
did yours?
Old Jan 24, 2009 | 08:00 PM
uberEFtuner's Avatar
I have a solution; listen to a CD or an IPOD. I know I,m an azzhole, but FM radio sucks donkey *****!
Old Jan 25, 2009 | 04:45 PM
You're right. Pay a little more for better quality. It's just times are hard right now. DAMN YOU ECONOMY!!!
Old Jan 25, 2009 | 06:35 PM
Rayz_Si's Avatar
From: Land of the Hillbillies and Shotguns, Ontario, Canada
lol you got it buddy, i wish i could afford the oem stuff my recpetion sucks with the hids on, i don't know if a relay kit will help
Old Jan 31, 2009 | 10:13 PM
98civdx's Avatar
Master Detailer
x2
Old Feb 3, 2009 | 01:17 PM
brutekiller787's Avatar
Originally Posted by 98civdx
x2
x3
EJ1 RaceBound
Honda Civic (2006 - 2015)
11
Sep 29, 2011 08:13 PM
Espyone
Lighting
Dec 15, 2010 03:07 PM
TypeRvtec18
Jan 21, 2003 08:19 PM
CheezeFrog
Aug 8, 2001 03:27 PM
OneThirtyEight
Jun 22, 2001 07:30 AM
