Lighting HID/Xenon kits, Retrofits and Associated Topics
fogs lights keep shorting out
Old Dec 28, 2008 | 08:20 PM
pjr710's Avatar
Default fogs lights keep shorting out
i have an intercooler and foglights on my 97 coupe. everything worked perfectly for like 4 months. then one day my foglights just went out and i found out the fuse blew.
so today i took off the bumper and checked everything out. i taped up a little piece of wire showing from the foglights. i got them to work, then i put them back in the bumper and back on the car, i had to force the bumper on a little big because its really tight w/ the intercooler piping. anyway, once i put the bumper on .. i turned on the lights nad they shorted out again. i have no idea whats causing this, i've checked every wire there is and they all look good. what could it be?
Old Dec 29, 2008 | 05:33 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: fogs lights keep shorting out
It must be a +12V power wire shorting out to the frame or something else grounded to the frame. Did you check to see if the wires are touching any metal parts after the bumper is installed?
Old Dec 29, 2008 | 10:43 AM
pjr710's Avatar
well theres no exposed wire hitting anything, the housing of my foglights is touching my intercooler piping, thats about it
Old Dec 29, 2008 | 11:31 AM
Community Builder
Well just to rule that out, try putting a piece of cardboard or something between the foglight housing and the IC and see if the lights work.
Old Dec 29, 2008 | 05:06 PM
pjr710's Avatar
i connected the ground to a better source, that solved the problem
Smash03
Sep 25, 2006 06:46 AM
obd1integ
Aug 17, 2006 02:23 PM
accord0494
Jul 29, 2005 09:02 PM
GOTNOS
Feb 22, 2003 02:40 PM
